Old 01-31-2011, 08:39 PM   #1
scrapmetalart
Junior Member
2 pc drive shaft in a shortbed?
I have a 6 cyl/3 speed long bed. Im shortening the frame for a shortbed & took the 2 pc driveshaft to be shortened 12" in the front shaft. The shop was a little concerned at how short the front shaft will be after the 12" is taken out...
Any one have pics of a stock 2 pc shaft for a shortbed & maybe some dimensions.
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 01-31-2011, 09:15 PM   #2
1low
Re: 2 pc drive shaft in a shortbed?
Why not build a one pc. less ujoints no carier bering winwin
1low is offline   Reply With Quote
Old 01-31-2011, 10:16 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, factory short bed 6 cylinder 3 speed trucks had 1 piece driveshafts.
By the way, I think I have used your products (fenders) on some choppers I built a few years ago.
Old 01-31-2011, 10:24 PM   #4
scrapmetalart
Junior Member
Is the trailing arm crossmember in the way when using a 1 pc & lowering 7" in the rear?
Thanks for the business. Build more bikes!!!!!!!
Old 01-31-2011, 10:48 PM   #5
71lowboy
71lowboy's Avatar
Not sure about the trailing arm but I went one piece in my short bed. got a custom one built to length and balanced for like two hundred and had it in my hands a few days later. let me know if you want the shops number.
1971 c-10 short step
2008 jeep grand cherokee
I used to be into firebirds but got tired of changing floors lol Chevy trucks the only way to roll
MY BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=329703
71lowboy is offline   Reply With Quote
Old 01-31-2011, 11:07 PM   #6
scrapmetalart
Junior Member
My local shop will make me one. I guess i need to step back & rethink this.
Old 01-31-2011, 11:11 PM   #7
bigblockorange
I have 3 short bed trucks only one has a factory 2 pc shaft they both work fine to me it doesn't matter as long as the bed is short.
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!!
bigblockorange is offline   Reply With Quote
Old 02-03-2011, 08:27 PM   #8
scrapmetalart
Junior Member
had the front shaft shortened 12 for the shortbed conversion.
I might go 1 pc when I put in the overdrive
