How has this truck been lowered?
I have seen pics of this truck around the forum a few times and love the stance of it. Does anyone know of a writeup on it or know how they lowered it?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
Re: How has this truck been lowered?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB Last edited by cstm68; 02-01-2011 at 01:12 AM. |
BlahBlahBlah
I like that color. From the looks of the front tires Id say its bagged.
Really could have used 3/4 length headers!
What would it take to get that stance? I guess he had to c-notch the frame to get that low. It looks like the bed has been raised too. Do you get that stance just by bagging it?
Kill Bill...et
That truck is ridiculously nice! But yeah, spindles, bags, a notch, and maybe blocks and you too could run at that altitude. I wouldn't guess that the bed floor was raised. Oh yeah, your signature is great!
#7 | |
Yea I love that truck... I wish I could find a detailed writeup on it.
there is a write up in the link in post 2, the bed floor is stock but has a "show deck" wood floor over the steel floor so it sits about 2'' higher. my 68 has a notch and bocks in the back with d2600's and the front is 2 1/2'' spindals and d2600s with 20's all the way around and it sits lower than that, i dont think this truck is aired all the way down.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
The link really only tells you it's air ride but doesn't give you details. I'd really like toknow details... Like spindles... How the rear end is setup... Where they got the center console.... Things like that.
Btw... Cstm.. Been following your build. Nice job!! Posted via Mobile Device
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build Last edited by funkytechmonkey; 02-02-2011 at 08:33 PM. |
Sofa King Crazy!!
It is definetely NOT airred out all the way, and that stance looks great. Mine has the same stance when I air it out with a little rake to the front and I have 20s and 22s. This one looks like 22s all around. I notched the rear with a mini notch and just did plates and cups in the front with 2.5 in drop spindles. I cut the cups down 3/8 of an inch to lower it a little more. This truck has a four link settup in the rear to keep the alignment correct at any height (and from what it looks like) a dropmember in the front, more than likely, since it is Porterbilt.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() Last edited by Slick67; 02-03-2011 at 12:04 AM. |
That truck doesn't look like it could "air out" too much, the headers are only a couple inches off the ground at that height.
Like mentioned earlier, truck really could have used 3/4 length headers, but oh well....The truck is killer regardless! |
man I love that color.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#13 |
A stage 2 suspension from porterbuilt would get you that stance with the factory x member. Mild c-notch in the rear
Posted via Mobile Device |
#14 | ||
VA72C10
![]() Join Date: Mar 2008
FYI...You can achieve the stance pictured with a complete kit from ART or Porterbuilt (stage 2 mild drop)...or you can piece it together with early classics or CPP drop spindles, airbags with bag brackets in the front, and bags in the rear on the trailing arm with a c-notch to the frame. Will need shocks for a bagged truck and some sort of air management or schrader valves (for manual filling/dropping)
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#15 |
funkytechmonkey- thanks for the compliments on my build.
slick67- i belive it has 20's all the way around and iv seen othe articals before on the build of this truck and i think it has a factory xmember.
