Old 02-01-2011, 12:27 PM   #1
jimmydean
jimmydean's Avatar
My grille is a mess.
So I was looking at options and all I find are the 64-66 single headlight style. I have seen a few dual headlight setups used, but none have the headlight brackets. I looked at the LMC catalog and they show the brackets for singles, but not duals.
My question to the grille experts. Are the headlight brackets (buckets) the same for single and dual? If I wanted to swap my '66 grille for a 60-62 with duals, I just need a second set of buckets and adjusters? Or will I be on an endless search for the holy grail of grille parts?
<edit> Will a 60-62 even bolt up on a '66?
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-01-2011, 12:49 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: My grille is a mess.
the upper outside hole in your support should match all 7 years chev and gmc, the others you will have to drill new holes
you will need to find a 60-61 complete grille out of a c/10,20,30 to do your swap. nothing on your 66 grille itself will interchange.
once you get the 60-61 grille, all you will have to do is drill the extra holes, and plug it in.
Old 02-01-2011, 01:00 PM   #3
jimmydean
jimmydean's Avatar
Are the lights a different size? Why can't I just put the buckets in it from the '66? I found a new set of headlight adjusters for it, are the buckets THAT different?
Now I want to get it just to see
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-01-2011, 01:30 PM   #4
padresag
won't the GMC buckets work?
ron
padresag is offline   Reply With Quote
Old 02-01-2011, 01:54 PM   #5
jimmydean
jimmydean's Avatar
LMC only shows one part number for the headlight mount, 36-4720 for Chevy/GMC 62-66. Anyone else offer this part?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-01-2011, 02:53 PM   #6
jonzcustomshop
1961 crewcab
dual headlight bulbs are actually smaller than singles, so yes.. it is all different
gmc buckets.. and most likely most 60-66 gm dual headlight buckets and lamps will work, but the grille headlight ring, and headlamp /grille mounting bracket are unique.
Images:
1)60-61
2)60-65 gmc
3)64-66
4)62
5)63
Old 02-03-2011, 08:34 PM   #7
blackmopar
i never realized the headlights were bigger on the singles - i have a 60-61 dual headlight grill onmy 64 and im running plain jane h5006 - 5-3/4 rings
blackmopar is offline   Reply With Quote
Old 02-03-2011, 08:51 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Dual headlamp systems use four 5 3/4" bulbs. Single headlamp systems use two 7" bulbs. The headlight buckets and retaining pans are unique to each style.
