Old 02-01-2011, 04:55 PM   #1
b00sted
b00sted's Avatar
Is there a secret way to prevent
The hood from bending in the middle? Mine hasn't but after looking through here I see allot that has.. Does these trucks need a softer spring?
Is there one available?
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 02-01-2011, 04:57 PM   #2
S10Fan
Old Heap Driver
Re: Is there a secret way to prevent
Keep grease on the hinges. The white lithium grease, comes in a rattle can is perfect. Give them a shot once a month.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-01-2011, 04:59 PM   #3
cochino12
It followed me home?
cochino12's Avatar
you can also buy supports from lmc
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-01-2011, 05:11 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
When you close the hood, PUSH BACK -NOT UP- first then pull down. This helps reduce the amount of downward force on the hinges to get them to close up. Now on the 81 and newer setups the hinges are way different and require less downward force to close them.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-01-2011, 05:17 PM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
I had the same problem, did some research and talked with a body friend of mine and he said the best thing was to get new hinges, I had used lithium grease on my old hinges and it helped a little bit but when I got my new hood I just ordered new hinges and springs from LMC truck...work like a charm now....you can use the hood stiffeners (in fact I bought them for my old hood before I bought a new one) they will start to work the kink out and keep it from doing that but if you have new hinges I don't think you need them as long as you keep them greased
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-02-2011, 01:35 AM   #6
Gordonr1973
Home Built '87
Gordonr1973's Avatar
x2 and keep the hinges greased
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-02-2011, 01:58 AM   #7
Benelli
Watchin the rust grow
Benelli's Avatar
Too little too late for my truck but everyone here as gave sound advice.
another thing you might consider is just...be gentle with them, instead of slamming them shut or throwing them open.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 02-02-2011, 09:02 AM   #8
BigBlocksRule
They're supposed to bend where they typically do. They're made this way so they fold up in a frontal crash instead of pushing straight back and decapitating the driver and passenger.
I've tried a lot of stuff over the years to keep 'em freed up, you're almost always better off with new.
BigBlocksRule is offline   Reply With Quote
Old 02-02-2011, 09:27 AM   #9
78 Chevyrado
New NOS hinges and Grease. I bought some aftermarket hinges before and they werent any tighter than the old sloppy OE stuff. They bend because of crappy hinges, and shutting the hood from off center. My truck (78) did'nt have a bent hood, neither did my 77 and my dad and grandad greased those hinges religiously.
I put NOS hinges on it, and keep em greased and now once you open the hood about 12 inches, it'll slam up the rest of the way on it's own if you don't stop it. And its real tight too. I can shut it with one finger. I grease it at oil change interval, and more if I'm opening and closing a lot because I'm working on something. All depends on how much I use it.
The NOS hinges are worth it strictly because the aftermarket versions aren't work anything, and ya gotta have something.
Grease it, Shut it in the center, Don't slam it (If you gotta slam it it needs adjustment), and the biggie: Don't let anybody else shut your hood for you, ever!
78 Chevyrado is offline   Reply With Quote
Old 02-02-2011, 09:32 AM   #10
b00sted
b00sted's Avatar
Thanks guys for the great advise... Mine is not ment yet and the hood opens smoothly.. I am th e3rd owner of this truck.. As a matter of fact this truck oil change decal in the windshield say's.. next oil change at 58k miles.. it has 63k on it now and I am about to change it to Mobile One...
Oh and this decal is from 1999.LOL...
Old 02-04-2011, 01:13 PM   #11
Toxic Redline
Toxic Redline's Avatar
if your worried just buy those hood shims from somewhere. but its you're baby dont be treating it like junk and you wont have a problem
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-04-2011, 01:39 PM   #12
463
463's Avatar
FLUID FILM
spray them every two months and no bends ever FLUID FILM on doors all movement points. http://www.fluid-film.com/
463 is offline   Reply With Quote
Old 02-04-2011, 01:57 PM   #13
Restrorob
The One And Only !!!
Restrorob's Avatar
^^^^^^^ Best stuff on the market, Doesn't collect dirt/dust and doesn't dry out like grease and leaves no white residue behind....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
