Old 02-01-2011, 06:24 PM   #1
slick78
brake light prob
so this is what happend. like an idiot i hooked up my battery cable backwards and for some reason, my left brake light dont work now. the running light comes on,but when i hit the brake it dont work. i need help please. thanx. its a 78 chevy if that helps any. thanx for any help.
slick78 is offline   Reply With Quote
Old 02-01-2011, 07:53 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: brake light prob
Coincidence I think....change the bulb
ont_guy_38 is offline   Reply With Quote
Old 02-03-2011, 12:28 AM   #3
slick78
So i changed the bulb and nothing. What do i do?
Old 02-03-2011, 01:40 AM   #4
andyh1956
does the left rear turn signal work? the brake light & turn signal use the same circuit & bulb filament. if the turn signal does work then the brake light circuit in the turn signal switch is bad. if it does not work then the switch OR a circuit problem from the switch back OR a ground is most likely the problem.
andy
andyh1956 is offline   Reply With Quote
Old 02-03-2011, 02:49 AM   #5
slick78
Unhappy Re: brake light prob
Well actually my turn signal lever broke so i use hand signals for now. But my turn signal was working fine and brake light too. This problem just started when i hooked up the battery terminals incorrect. I probably got a short. Idk.
Old 02-03-2011, 08:21 AM   #6
ont_guy_38
ont_guy_38's Avatar
You can see if it flashes by turning on the emergency flashers also...there is only one wire that goes to the back for both brake lights so if one works then you are getting power back there...you have to check the wiring where its splits off to each light.Doubt it has anything to do with you hooking the cable up wrong
Old 02-03-2011, 12:55 PM   #7
slick78
Ill check it out tonight after work. Hopefully its something symple. Thanx again for the help. Ill keep you guys posted.
Old 02-03-2011, 08:06 PM   #8
glhman222
check the ground at the tail light
1979 Chevy C10 Longbed
glhman222 is offline   Reply With Quote
Old 02-06-2011, 01:10 AM   #9
Toxic Redline
Toxic Redline's Avatar
Make sure you have enough blinker Fluid
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-08-2011, 06:41 PM   #10
slick78
Red face Re: brake light prob
lol yeah i checked my blinker fluid,im ok. so i come to find out my turnsignal dont work neither on the left side. u guys think it could be my turnsignal switch? i have to brake light or turnsignal. help please!!
Old 02-08-2011, 07:02 PM   #11
lakeroadster
Did you check your fuses?
Might have wasted the flasher relay also?
lakeroadster is offline   Reply With Quote
