Old 02-01-2011, 06:28 PM   #1
C-10 simplex
RE: Small engines:
1) Will a vertical small engine, for example a mower engine, work ok with the shaft horizontal? In other words, the engine is basically now tilted on it's side from it's usual position?
If not that's ok:
2) What are some decent brands of small engines? i'm basically wanting/needing about 5-10 hp, but would like to know about decent brands in general for now.
a) i'm basically concerned where they are made, money is not really a top priority here. If it's made in china or s.e. asian countries, then i would shy away from it---unless you can recommend a decent brand---if such exists? Japan is ok, but for this project, i would prefer made in USA or at least N. america (but not mexico).
3) How would i go about attaching a gilmer type pulley to the shaft?
C-10 simplex is offline   Reply With Quote
Old 02-01-2011, 06:33 PM   #2
63chevyll
gets board easy.......
63chevyll's Avatar
Re: Small engines:
yup, you cant run a vertical engine ( horizontal shaft) on its side
what are you building
63chevyll is offline   Reply With Quote
Old 02-01-2011, 06:35 PM   #3
threeonthetree
threeonthetree's Avatar
Re: Small engines:
1. the oils gonna be right on the piston i dont think they will run like that enless its a 2 cycle
2. brigs and strat or honda are some good brands.
3. not sure man what your asking. ud have to get the right size pulley for the shaft then have some way to clamp it to the shaft. i think most shafts have a notch in them then a bolt on the end of the shaft. and they are usually tapered
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 02-01-2011, 06:37 PM   #4
threeonthetree
Re: Small engines:
they make horizontal shaft small motors
you can get them out of snow blowers
or just buy a brand new one.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-01-2011, 06:39 PM   #5
threeonthetree
Re: Small engines:
Are Briggs & Stratton engines, pressure washers, generators, etc. made in the U.S.?
Over 90% of our engines and products are manufactured in the USA.
The only exception would be the Vanguard horizontal shaft, V-Twin and 3-cylinder liquid cooled engines (All Vanguard vertical shaft single cylinder engines are made in the USA). The Vanguard horizontal shaft and V-twin engines have many of its components made in the USA and are assembled in Japan.
All Vanguard engines are engineered in the USA.
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 02-01-2011, 09:24 PM   #6
C-10 simplex
Re: Small engines:
i didn't want to spill it for fear of ridicule, but what the heck. Besides, maybe you guys can help.
It may take a few hours/days to get a picture drawn up so as to better describe what i'm trying to do.
Stay tuned.....if you dare.
Old 02-06-2011, 05:54 AM   #7
C-10 simplex
Re: Small engines:
Sorry; Project cancelled and put on hold until further notice due to being too busy. Better organizational strategy(i think so at least) means doing maybe 2 things at a time vs. 6 things at a time.
For what it's worth, i was trying to build a swim spa; i was going to use the engine as a propulsion for a propeller. In this case, the "propeller" was the fixed engine fan from a 79 blazer.
i was going to mount a gilmer puller on the shaft of the engine. A 2x3 rectangular metal tube would extend downwards below the engine into the water, say 18" to 24" and a SBC water pump would be attached to this metal tube. Guess what i would attach to the water pump?
Thank you for everyone's concern and perhaps we will speak again in a few months hopefully.
Old 02-06-2011, 09:38 AM   #8
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: Small engines:
That is actually a pretty good idea. If you get back to it keep us posted.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 02-06-2011, 10:45 AM   #9
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Small engines:
Well,
Being in the small engine/ATV/UTV/Watercraft business, I'd venture to say 10hp would never pull that much drag, Especially trying to start the engine with that big fan under water.
I would suggest using a pump outdrive and drive shaft from a blown/wrecked watercraft, With the steering cone the water stream could be directed in different directions. A 20 or 25hp electric start Kohler Command Twin should spin the outdrive pretty well.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-06-2011, 06:58 PM   #10
C-10 simplex
Re: Small engines:
i was thinking about that very aspect---hp requirements. And i was thinking that yes, 5-10hp would probably not be enough.
Old 02-06-2011, 07:08 PM   #11
C-10 simplex
Re: Small engines:
P.S. If anyone is not familiar with what a swimspa is:
http://www.endlesspools.com/endlesspool/index.html
http://www.swimex.com/home/
These are very good products, but i was trying to save a few thousand by trying build my own. The 2 above are anywhere between $11K and 23K. If my idea works i think i could build one for about 3-5K.
i still have not completely ruled out just buying one.
Old 02-06-2011, 08:25 PM   #12
TugOwar
Re: Small engines:
Hey, you could drive the pump with a SBC and buy a surf board!
TugOwar is offline   Reply With Quote
Old 02-06-2011, 08:55 PM   #13
Restrorob
Restrorob's Avatar
Re: Small engines:
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-08-2011, 11:06 PM   #14
C-10 simplex
Re: Small engines:
i did in fact consider using a sbc for power and still am considering it since it's cheap.
There's a video on 'tube with someone using a kayak with one of these spas. Also, i think the surf machines do exist also.
