I would love to have the knowledge of how to ground my Fuel Sending Unit. I can't see a ground anywhere by just looking behind the seat. Installed a new unit but it still isn't functioning correctly.
Can I get a little help with this one people??? :} |
its all about the +6 inches
Re: Fuel Sending Unit to Ground question.
the sender is grounded to the tank
the tank (assuming it's bolted to the cab) is grounded to the cab the cab is grounded to the frame the frame is grounded to the battery You probably have another problem. Whats the actual fault? |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
My favorite link.
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Added that one to my favorites!
-Scott- |
![]() Join Date: May 2010
What type of problems are you having. I could not get mine to read properly until a board member suggested I replace the resistor on the back of the fuel gauge and problem was solved.
The gauge read 1/8th of a tank for 6 years or so, never drove the pickup I just kept it in storage. Had a new sending unit installed since I had already bought it b4 I started reading all this good stuff on this board about the different possibilities that might b the problem. :}
After installation and a fill up, it went through half a tank rather quickly and slowed down around a half of a tank and I thought it was going to work for me but it didn't move from there and has slowly eased down to 1/4 tank. :{ I tried to work after the new sending unit was installed is what puzzles me... |
Here's my original thread regarding my fuel sending issues.
http://67-72chevytrucks.com/vboard/s...d.php?t=404114 |
Thanx people!!! This should keep me busy for a while. :}
