Old 02-01-2011, 09:57 PM   #1
tek970chevy
tranny question
i have a 700 in my 70 and it just went out... thinking of getting a 400and was wondering if i had to change/modify anything to put it in... from what i know, the driveshaft as been shortened to fit the 700 from when my dad had it... dont know if i have to do anything else... please help.. thanks
tek970chevy is offline   Reply With Quote
Old 02-02-2011, 12:37 PM   #2
tek970chevy
Re: tranny question
Forgot to ask if anybody knows... when it comes to the torque converter. What exactly is the STALL?
Old 02-02-2011, 01:04 PM   #3
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Re: tranny question
here is a link for the reverse swapping 400 to 700r4
http://67-72chevytrucks.com/vboard/s...ad.php?t=33266
You do realize that your going from an Overdrive tranny to a 3spd?
And for your second question are you asking what the stall speed should be or ?
here is an article I liked regarding converters
http://www.carcraft.com/techarticles...ter/index.html
Hope that helps, I'm sure someone who has done it will chime in.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 02-02-2011, 04:43 PM   #4
tek970chevy
Re: tranny question
So is overdrive considered better? Its my understanding that it helps mpg but what I really want something strong that'll pull
And yes I wanted to know what the stall speed should be
And if I do get the 400 will I be able to use the same dipstick and cable from the 700?
Old 02-02-2011, 04:44 PM   #5
tek970chevy
Re: tranny question
Old 02-02-2011, 04:54 PM   #6
custom1970
Member
custom1970's Avatar
Re: tranny question
unless your trying to go with and original set-up, i think you'll be better with the 700, better fuel economy, better for your engine (lower highway RPM), among other things. And i definitely would not use a dip stick from a different type of trans
custom1970 is offline   Reply With Quote
Old 02-02-2011, 05:13 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: tranny question
it depends on how your truck is set up, and what you'll be using it for.
You mentioned pulling... it you tow a lot, then go for the 400
Even just dropping a 700 in 3rd for towing, it's still not all that strong.
If your truck is a 1/2 ton, there's a good chance that you have a 3.07 gear and that is a good freeway gear to begin with. If you had an overdrive and the 3.08 gear, your MPG may actually go up with the 400 trans.
The 400 does not use a kickdown cable at all. You will want to hook up a kickdown switch. You don't NEED it, but it makes things easier, and it will extend the life of the trans a bit.
You will want a dipstick and tube from a TH400.
As far as your stall speed, it again depends on intended use, gearing, and how your engine is built. However, if it is a stock engine, then just get a converter for a stock truck.
Old 02-02-2011, 05:16 PM   #8
cdowns
cdowns's Avatar
Re: tranny question
you cant use the 700 dipstick for the 400/you cant use the driveshaft you have/ there is no cable with the 400 it has electric switch that you need to hookup
Old 02-02-2011, 05:22 PM   #9
So.Cal.Super
It'll Buff Out!
Re: tranny question
When it comes to Stall I will point out a paragraph from the link I posted.
After you’ve declared your intent for the car, you also need to tell the tech guy the weight of your vehicle, and the following information about your powertrain combo:
• Displacement
• Compression ratio
• Cam profile (duration at 0.050-inch lift, lobe separation angle)
• Carburetor or injector size
• Transmission model year and gear ratios
• Rearend gear ratio
So my next questions are
what do you plan on Hauling?
What motor is in the truck?
Is it stock? will it stay stock? if your going to build it, how long after the new trans goes into place?
What rear end is in the truck?
I've seen plenty of SBC Run great with th350's and 700r4
The 400 is a monster and with a stock 350 IMO would be a dog with a 400
Then there is the 4L60 Option also
I have a 402 with small build up maybe 320hp th400 and 4:10 rear that I avg 7.5 mpg with but I also drive it at 70mph and I hate that it's almost turning 3000rpm. Not good for the life of the engine.
Your going to want to use the correct dipstick like custom said. the cable i'm not sure on.
Man Card Rules
Old 02-02-2011, 05:23 PM   #10
So.Cal.Super
It'll Buff Out!
Re: tranny question
I took too long to type
Man Card Rules
Old 02-02-2011, 07:37 PM   #11
tek970chevy
Re: tranny question
so if it doesnt have a cable the only thing it really has is the shift linkage to the steering column?... and if i get the the switch where would it have to be hooked up on and how?
Old 02-02-2011, 07:38 PM   #12
tek970chevy
Re: tranny question
i cant use the driveshaft i have??? never heard that before.. why??
Old 02-02-2011, 07:57 PM   #13
cdowns
cdowns's Avatar
Re: tranny question
because it wont work because they are different types
Old 02-02-2011, 08:02 PM   #14
tek970chevy
Re: tranny question
? what do you mean??
Old 02-02-2011, 08:13 PM   #15
So.Cal.Super
It'll Buff Out!
Re: tranny question
Different Transmissions are different lengths. When you go from a 400 to a 700r4 you have to have the drive shaft shortened. So in your case you will need a longer driveshaft to go from the 700 to the 400
Man Card Rules
Old 02-02-2011, 09:49 PM   #16
Longhorn Man
Re: tranny question
Shift linkage and a vac line, and then the kickdown switch, which you'll be best off getting an aftermarket deal like maybe lokar. Stock was a button mounted on the intake that the arm on the carb linkage would press at wide open throttle. You'll want positive to the switch, then the other wire off the switch goes to the terminal on the side of the tranny. It's been a couple years since I looked at one so I can't say where it is on the tranny, other than on the side of the case and kinda low.
The drive shaft issue... most shops won't make a drive shaft longer. They'll chop the ends off your shaft and make a new tube though. It'll be cheaper to locate one off a TH400 truck with the same type engine you have (small block/big block/inline6), but that could be hard to locate. The yoke may need replacing too, not sure.
Old 02-03-2011, 08:00 PM   #17
tek970chevy
Re: tranny question
thanks guys that helped alot... talked to my dad, and he advised me to get the original 350... last time i didnt take his advice i ended up spending way much more...but i still kinda want the 400 lol
Old 02-04-2011, 11:26 AM   #18
Wrenchbender Ret
Re: tranny question
The 400 uses a larger yoke then the others.
Wrenchbender Ret is offline   Reply With Quote
