Old 02-02-2011, 12:30 AM   #1
nikwho
nikwho's Avatar
Air bag kit for 2nd gen camaro subframe?
Im looking for an economical air bag kit for just the front of the '59 w/ a '79 camaro subframe. any thoughts?
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 02-02-2011, 12:40 AM   #2
nikwho
nikwho's Avatar
Re: Air bag kit for 2nd gen camaro subframe?
Would something like this work?
http://www.auto-addicts.com/product_p/baga-25aaaa.htm
I dont need a compressor. I have some 2,200 psi air bottles that I can easily refill. I was thinking that a hidden dial regulator like what you would use to adjust the output pressure for your air compressor would work. I dont want "switches" in the cab. What do you guys do? I would think that I could make something instead of buying these:
http://www.auto-addicts.com/ProductD...F7081&CartID=1
'68 GMC - BBC/TH400
Old 02-02-2011, 07:12 AM   #3
S10Fan
Old Heap Driver
Those bag cups are what you need, but you will still need to trim quite a bit from the bottom of the spring tower. The trimming is necessary to allow good clearance around the bags.
My 73 C-10 is bagged and the 50 I'm building will be bagged. I wouldn't run air ride without switches in the cab. I've had friends that started out with tanks and eventually went with on board compressors. If you develop a leak you'll need air asap.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-02-2011, 01:33 PM   #4
nikwho
nikwho's Avatar
That makes sense. Do you have pics of the neccessary trimming by chance? Maybe I will start with the high pressure air bottles and move to a compressor later. Are those bags acceptable for using on a camaro? I want to be able to air it out to the bump stops and be able to inflate it to normal stock ride height. Im a total noob when it comes to air bags. Thanks for the help guys!
'68 GMC - BBC/TH400
Old 02-02-2011, 08:31 PM   #5
S10Fan
Old Heap Driver
Those bags look OK but I've not heard of the brand.
As far as cutting the spring tower.....I'll try and get some pictures this weekend of my S-10 chassis to give you a general idea. My setup will be using the same style bag cups, I'll get you some pics of those as well.
Bryan
Old 02-02-2011, 09:03 PM   #6
nikwho
nikwho's Avatar
Ok, I am going to give making my own brackets a whirl. I ordered two each of the upper and lower universal brackets. I'll need to pick up some 5.5" tubing/pipe to weld onto the upper to space it down. I would REALLY appreciate some pictures to help guide me along! I want to be able to get it up to the factory-ish camaro height, as well as drop it down. Here are a couple of other bags I was looking at:
Slam Specialties RE Series 5" Air Bag Single Port 200psi
Sale Price $85.00
5.5" Diameter. 2.9" Collapsed Height 8.0" Extended Height
-or-
Slam Specialties RE Series 6" Air Bag Single Port 200psi
Sale Price $85.00
6" Diameter. 2.9" Collapsed Height 10.0" Extended Height
I was leaning toward the 6" bag since its extended height is a couple of inches taller. I want to be able to get it up to the normal ride height of the camaro suspension.
Thanks a bunch! Nik
'68 GMC - BBC/TH400
Old 02-02-2011, 09:23 PM   #7
S10Fan
Old Heap Driver
I don't think you want to space them down. I think you'll have a better visual once I post some pictures.
BTW.....You may want to post some bag questions in the suspension forum. You may get a quicker response.
Bryan
Old 02-02-2011, 09:27 PM   #8
S10Fan
Old Heap Driver
Here's a link to check out. these deal with S-10 frames but there isn't that much difference for what you're trying to accomplish.
http://www.blazinlow.com/index.php?what=tech/bags/bags
Bryan
Old 02-02-2011, 09:37 PM   #9
nikwho
nikwho's Avatar
Good info! thank you! I see what needs to be cut now. Looks like quite a bit of work! haha. I better get on it! I wanna start working on a GTO project one of these days!
'68 GMC - BBC/TH400
Old 02-02-2011, 10:20 PM   #10
entourageguy
Yellow truck club
entourageguy's Avatar
over in the suspension forum there are a few guys offering deals right now
here is one
http://67-72chevytrucks.com/vboard/s...d.php?t=440242
AVS Jason is a nother one
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-02-2011, 11:29 PM   #11
nikwho
nikwho's Avatar
Thank you. I found that earlier after posting this. I actually have spoken with Jason today and will get all set up from him. Thanks!
'68 GMC - BBC/TH400
Old 10-01-2011, 08:06 PM   #12
ZR2RICK
ZR2RICK's Avatar
I HAVE PICS OF MY BAGGED 57 IN MY BUILD THREAD IN THE " PROJECTS AND BUILDS SECTION, http://67-72chevytrucks.com/vboard/s...d.php?t=484701 HOPE THEY HELP., oops sorry for the caps.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
