Old 02-02-2011, 03:51 AM   #1
layingC10nK5
need advise on brakes....
Has anyone tried this brake kit? Or any of their products?
layingC10nK5 is offline   Reply With Quote
Old 02-02-2011, 12:13 PM   #2
CheyenneShop
CheyenneShop's Avatar
Re: need advise on brakes....
I too am in the market - so I wll be watching this one.
I called them to see what spindle they run with their kits - ECE or Western was the answer.
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 02-02-2011, 12:40 PM   #3
c10seconds
c10seconds's Avatar
I think project "incredible hulk" is using these brakes. They look to be a quality product. Its in the builds section somewhere
c10seconds is offline   Reply With Quote
Old 02-02-2011, 03:10 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
why not check out ECE? I have had very good customer service from them, used their Front susp rebuild kit and love it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-02-2011, 04:13 PM   #5
CheyenneShop
I don't think they offer anything bigger then a 12", and no rear set up? Plus it never hurts to shop around.
72 3/4 long 4X4
69 SWB "Prospector"
Old 02-02-2011, 08:40 PM   #6
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Anyone know how much those rotors weigh?
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 02-02-2011, 09:29 PM   #7
layingC10nK5
ok i spoke with them and they have the 71-72 spindle, i have 73+ balljoints. can i make it work? i would have to remove my lower arms to have them pressed again.
Old 02-02-2011, 09:43 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes.
You will need to change your upper ball joint to the 71-72
version.
The lower ball joint is the same.
The outer tie rod will have to be changed to the 71-72 version.
Pretty simple if you want these brakes.
Keith
Convert to disc brakes.
Old 02-02-2011, 09:45 PM   #9
SCOTI
SCOTI's Avatar
Yep, you'd need to use 71-72 ball joints. Tops obviously are a bolt-in swap, the BJ would have to be pressed out & swapped for the lowers if it's not already the same size (might be).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 02-02-2011, 10:38 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Keith is right, the lower ball joint is the same 71 through 87. Upper is 71-72 and 73-87 fitment.
Old 02-02-2011, 11:32 PM   #11
layingC10nK5
Cool Re: need advise on brakes....
Thats good news, I can do the uppers as they are bolt on. The tie rod shouldnt be a problem as im running a dropmember. Thanks for the knowledge guys.
Old 02-02-2011, 11:45 PM   #12
lolife99
lolife99's Avatar
What spindles do you have on there now?
Keith
Old 02-03-2011, 01:01 AM   #13
project67-stepside
project67-stepside's Avatar
they make the parts for the mcgaughys kits ...
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
Old 02-03-2011, 01:08 AM   #14
layingC10nK5
Stock 73 spindle. I have a 2inch Z so I didnt want to buy spindles till I mocked it up. I hope to lay 24"
