Old 03-14-2003, 12:01 AM   #1
72MARIO
72MARIO's Avatar
73-87 Power booster Mod to fit our trucks ?
I don' have a original booter for a C10 and I don't like the way that the original one looks. So do you see any reason I could'nt use a newer one? I may have to make a longer push rod and drill/ fill some holes but no biggie. I am in the paint and body work process now so I can weld and drill all I want.
Thanks Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-14-2003, 12:19 AM   #2
Piston
Piston's Avatar
I've got one from a newer truck (80's) and have been fitting it to the cab im working on. It's no big deal from what I can see. The bracket for the booster needs 2 additional holes drilled and I plan on cutting off the top portion of the bracket (the old 2 holes that aren't used). Then you'll need to make a longer push rod (about 3 inches longer I'm guessing).
Piston is offline   Reply With Quote
Old 03-14-2003, 12:30 AM   #3
barn9
Half a bubble off!
barn9's Avatar
You guys might try a search, I seem to remember seeing some good info concerning this mod in the past. This is one of those topics that we need a good, informative, article on, and then have it included in the FAQ section.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 03-14-2003, 12:42 AM   #4
casey
casey's Avatar
when you change booster and master cylinder what do you do with the purporsioning valve, did I spell that right
casey is offline   Reply With Quote
Old 03-14-2003, 03:14 AM   #5
Brad
Out of the carpool lane.
Brad's Avatar
Okay, it's been awhile since I had a '77 booster on mine, but I remember that I used a coupler nut to lengthen the rod and I had to drill 2 extra holes where it mounted to the firewall.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-14-2003, 04:34 AM   #6
dmnall
dmnall's Avatar
or you can always do the next best thing which I will be doing, just take the brake pedal off of the 73 - UP truck and remove the old one from our trucks (67 - 72) and just put the proportioning valve in the same spot as the 73 - UP... I plan on going this route since I am going to be swapping front Suspension from my 74 C10 to my 68 (so I can get the newer motor mounts and disc front setup), and I am just going to use the newer brake booster and master cyl.. other then that should not be too tough...
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
Old 03-14-2003, 08:54 AM   #7
72MARIO
72MARIO's Avatar
I plan on buying a Bare or Wildwood ADJ porp valve they look kinda trick I think. The old ones look GooFy. So you don't think there will be any problems Eh ?
2005 TAHOE DD
