Heater questions
Forgive me if this is a silly question. Is there a replacement heater defrost system for these trucks that doesn't require coolant lines. Maybe a electric system. My question is based on if you shave all the heater holes from the fire wall how do you get heat or defrost. This seems like a dumb question even to me but I want to completely shave the firewall smooth and all I've found so far require coolant line to get the heat. I thought they would have made some sort of electric system. Any help or advice would be appreciated. Maybe even a picture or two of how guys have theirs set up.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Heater questions
There is none tht I know of. There use to be an electrical heater box that was used in the Suburbans ubder a rear seat to help heat the rear area, but thats all I know of. All aftermarket systoms that I know of require the hot water that your engine produces to make heat. All AC systoms require the refrigerent to be pumped through the systom, so there are lines that need to go to an engine driven pump. You can always run the hoses through a less visable spot on the firewall. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Thanks Wes. I thought that might be the case. Are there any suggestions on how to run hoses out of sight? What are people doing if they shave the blower holes and the plumbing holes for the coolanr/fresh air supply to the heater assembly? Maybe they have no heat or defrost at all??? Living in the north it didn't occur to me not to have a heater. Not that I drive my C10 or Blazer in anything other than sunshine..lol. The blazer will be a roadster so on cool nights I would still like to have some heat on the toes. This helps keep the wife quiet as well...lol.
Jim |
![]() Join Date: Jul 2009
You could try something like this universal electric car heater that JC Whitney sells.
http://www.jcwhitney.com/deluxe-high...wx?filterid=j1 Mike Mileski Tucson, AZ |
I am a Referee of life.
Look thru some aftermarket AC/Heater installs.Many route the hoses over to the inner fenderwell and run them behind the lip of the fender.Some also run their wiring harness this way on the drivers side.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I'll have to do some more digging to see some pictures of what your describing. I figured if I'm going to the trouble of smoothing everything on the firewall I should have some idea how to route the coolant lines and wiring. Thanks.
