Solid axle swap on 97 swb
I have a 97 swb step side 1500 chevy. The truck is 2wd it has the vortec 350 and 4l60e trans. I have a 79 k5 blazer that was wreked and sits in my back yard. The blazer has the dana 44 axles. Now iv dun the solid axle swap before on the 2500 & 3500. I am just un shure where to hang the hangers on the rear up front on the truck. If any one has any thing it would help first time iv done this by my self thanks.
Posted via Mobile Device |
Junk Yartist
Re: Solid axle swap on 97 swb
A GREAT place to start
http://www.offroadunlimited.com/orus...?idCategory=18 My built 96 (R.I.P) A GREAT place to start http://www.offroadunlimited.com/orus...?idCategory=18
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
Wow great truck man i love it thanks for the site's and if you don't mind my asking was your swap easy and what was you total coast.
Junk Yartist
SUPER easy. I only drilled the holes in the frame. My wife (fiance at the time) did all the work. I had a cast on!
These are estimates of what I spent ORU kit 800 front springs 4" 250 rear springs 8" 800 steering kit 400 front axle built 600 wheels and tires 1200 driveshafts 300 There are cheaper ways to go obviously.
Windy Corner of a Dirty Street
Alderson95,
I know you mention that you have a D44 lying around but check this out. The ORU kit that works with a Ford D60 is on sale for $354! That is a heck of a deal....actually, what that kit SHOULD cost. A $1000 was way too much originally. http://www.offroadunlimited.com/orus...dproduct=10754 Jbclassix, I love that truck! The only thing I would do is ditch that electric shift tcase.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
[QUOTE=DirtyLarry;4457736]Alderson95,
I know you mention that you have a D44 lying around but check this out. The ORU kit that works with a Ford D60 is on sale for $354! That is a heck of a deal....actually, what that kit SHOULD cost. A $1000 was way too much originally. [QUOTE] Larry you miss read the ad. It is still way too much for this kit! Price: $699.95 List Price: $1,054.94 You Save: $354.99
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 Last edited by ghettoluxury; 02-04-2011 at 09:59 AM. |
i have don a solid axle swap before on this year of truck. i had olny dun it to the 3/4ton and they were all 4x4's. iv got a 95 2500 gmc with the swap and a duramax lb7 swap. and did you lose your truck or somthing.
We need pictures! We all love truck porn here.
#9 | |
Junk Yartist
I agree with Larry! Truck pictures are a must! Especially if it has a D-max!
Id post but i don't have the gold membership or somthing or for that matter a camra but i will ugrade my membership soon i hope and ill get a camra from my brother so ill ceep yall posted and sory about the truck i sold my 98 crew cab short bed 454 with 6in lift for 2200 so i know the feeling
iv considerd the dana 60's only problem is every body want's one so it makes them hard to find. if i could get one i would.
I like the idea of the D60 front. You're going to have lug patterns that don't match already (6 in front, 5 in rear) so it might as well be 8 all the way around...
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#13 |
If you have the blazer already you have everything you need. Roll the front axle under the truck (with the leaf springs and front hanger attached and center the wheel in the fender well. Weld the front hangers from the front leaf springs to the frame. Then take the rear hangers and shackles from the rear of the blazer and bolt them to the oppisite front leaf spring, this will put the flat part that used to be on the outside of the frame on the inside of the frame so that it can be welded in place.
![]() ![]() Now on the rear you may be able to roll the blazer axle under there with the springs and have them bolt right up to the hangers and shackles on the truck. If not you can blow both spring packs apart and add the extra blazer springs to the truck springs to get a level ride height. If this is done make sure you put new guide pins through the spring pack to keep them together.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 Last edited by ghettoluxury; 02-04-2011 at 09:51 AM. |
#14 |
Do not cut the cross member out, it is a very important part of the frame's structure. It will not be in the way, you may need to trim it after instilation of the front axle but not much.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
