02-02-2011, 01:32 PM | #1 |
"brand new second-hand"
fan switch on HI setting -not working
This has happened before but I can't remember what caused it-my fan switch works on all speeds except hi-I have a 69 with a/c - I think I replaced the switch last time but that was not the problem-I know someone has the answer-
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
02-02-2011, 02:25 PM | #2 |
Firefighter
Re: fan switch on HI setting -not working
It's probably your blower resistor.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
02-02-2011, 02:30 PM | #3 |
Junk Yartist
Don't they have a relay for high? I just fixed that problem on my 91 (I know, different truck...)My fan relay was bad. But I thought they had a resistor mounted inside the duct and a relay on the outside
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
02-02-2011, 02:33 PM | #4 |
It is most likely the blower fan relay. When I bought my '72 GMC with factory air, it only worked on low and medium. I was going to replace the switch and somebody told me that it was most likely the relay. I bought a new one for $15, installed it and now it blows on high. I think I read somewhere that low and medium just go through the switch but they route the high speed (read high amps) wiring through the relay. It's located behind the right side of glovebox, high up near the firewall.
Mike Mileski Tucson, AZ |
02-02-2011, 02:38 PM | #5 |
Alright Alright Alright
Where might you find on of these relays?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
02-02-2011, 02:41 PM | #6 |
The Older Generation
With A/C has a relay, heater only doesn't...
First pic is heater only, second is w/air. LockDoc
02-02-2011, 02:44 PM | #7 |
The relays can be found at any auto parts store.
02-02-2011, 04:40 PM | #8 |
Some of them have an inline fuse. It might be on the engine side of the fire wall at the junction block. It caries a lot of current & often the fuse holder its self gets burnt.
02-02-2011, 04:51 PM | #9 |
thanks guys-I knew you would know the answer-I'll get to fixing it. Steve
