Hood Hinge Lube ? oil?
what do you guys use to oil your hood hinges, i had mine powder coated and dont want to use something that will damage the powder coat........
"the other guy"
Re: Hood Hinge Lube ? oil?
i use white lithium....but mine aren't powder coated
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
"brand new second-hand"
30wt oil-then I wipe up the excess
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
Member
Same, i use motor oil, last much longer and cleaner than a wd-40 type product
What?
Same here. I use the spray can type with the red straw spray nozzle to get it where I want with out making to much of a mess.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#6 | |
It sprays in (with a straw) as a thin liquid, then "Gels" into a much thicker, almost grease like consistency... so it stays put. its also made to not attract grit/dirt(not sticky).. and it doesnt wash off as easily as oil. downside is.. its not cheap. other stuff i use is called Gunzilla... its a plant based dry lubricant spray. it also has some odd properties thats great for hinges and lasts longer then most light oils (WD40, motor oil, 3-in-1, etc) Last edited by MrDude_1; 02-02-2011 at 05:53 PM. Reason: i suck at spelling |
69' Chevy Stepside
![]() Join Date: Mar 2008
I think I used motorcycle chain lube on mine as well. Seems to work good!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
