Old 02-02-2011, 06:54 PM   #1
blue 72 gmc 4x4
blue 72 gmc 4x4's Avatar
Reproduction speedometers
What do you guys think of the repro speedos? Are they any good? My original one made a ton of noise so I took one from a parts truck and now its doin the same thing. I'm going to clean it and re-lube it but if that dont work I'm throwin it away!!!! I appreciate any input!!
1955 GMC Hydramatic
1959 Chevy Spartan 100
1969 Chevy C/10
1969 Chevy C/30 Bruiser
1972 GMC (Wrecked)
1972 GMC pickup..old blue
Restored Vent Windows
https://67-72chevytrucks.com/vboard/...d.php?t=766598
1955 GMC hydramatic build
http://67-72chevytrucks.com/vboard/s...d.php?t=429417
blue 72 gmc 4x4 is offline   Reply With Quote
Old 02-02-2011, 07:01 PM   #2
Fldawg
Fldawg's Avatar
Re: Reproduction speedometers
my stock one broke, got a repro and it works fine, now don't get a oil pressure gauge i,ve already went thru two of those. hope this has helped.......Tom
Fldawg is offline   Reply With Quote
Old 02-02-2011, 07:02 PM   #3
CORSAIR
CORSAIR's Avatar
I dont know about new ones, but the noise usually comes from the cable? It sounds like a hampster running in wheel? Take out the inner cable from the outter sheathing clean and re grease it and I bet the noise goes away?
Hope this helps
CORSAIR
"The Can't Family Lives Across The Street"
CORSAIR is offline   Reply With Quote
Old 02-02-2011, 07:07 PM   #4
blue 72 gmc 4x4
Hope this helps
CORSAIR
Thats exactly what it sounds like. I put a new cable on it not too long ago, may be the cold thats making it do that...have to check that out. thanks for the replys!
1955 GMC Hydramatic
1969 Chevy C/10
1972 GMC (Wrecked)
Old 02-02-2011, 07:10 PM   #5
blue 72 gmc 4x4
Cool..if it turns out mine is messed up Im getting a new one! Yea I had something like that happen when I ordered new window regulators from LMC. The gears stripped out on it when I rolled it up, so I called them up and they sent me a new one no problem.
1955 GMC Hydramatic
1969 Chevy C/10
1972 GMC (Wrecked)
Old 02-02-2011, 07:20 PM   #6
Fldawg
Fldawg's Avatar
my speedo started making the noise greased the cable and the speedo still made noise and then broke a week later,i think its just hit and miss with the the aftermarket gauges. i replace all mine when i did the restore
Old 02-02-2011, 07:34 PM   #7
blue 72 gmc 4x4
Thats what I was waiting for mine to do this morning where did you get it from, LMC?
1955 GMC Hydramatic
1969 Chevy C/10
1972 GMC (Wrecked)
Old 02-02-2011, 07:52 PM   #8
Fldawg
Fldawg's Avatar
LMC there less expensive there
