upholstery supplies
I'm not sure which section this belongs in but, I am having a difficult time finding the clips for bucket seat covers. I am looking for the ones that go on the center panels of the cover through the foam to the wire in the back, they look a little like a paper clip. Does anyone know where to purchase these, as I have several broken ones?
Re: upholstery supplies
do u mean hog rings? here is one from lmc with installation pliers
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=46
1990 chevy 4x4 with a 1940 IHC body |
no not the hog rings. These go on the center panel. They are about 1.5" with a loop on each end to hook the seat cover to the wire in the back of the frame.
They are like really strong thin wire. I would think you could use wire from a hardware store to achieve the same result as originals may be hard to come up with. Have you talked with an upholstery shop?
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Those are the ones. I will probably just make some. Figured someone may already make them and save me some time.
try Miami Rubber in Cincinnati, they supply all the shops
I am also looking for the same thing if any one has found them
any one find the clips Thanks
I ended up making mine. They are easy to make just difficult to figure out which size goes where.
