02-02-2011, 09:13 PM | #1 |
292 4x4 engine crossmember questions...
Is the 292 4x4 engine crossmember different from the 250 and V-8 ones? I have a 67 K10 that I bought with a swapped in 327. A bunch of stuff was stolen out of it when I had it sitting outside a friends shop making room in mine for it. I should have made room first but I saw it on Craigs list and drove 400 miles that same day to get it.........
For some reason I am thinking that the crossmember in the bed was angled because of the off set mounts on a 292. It was 5 years ago and I am finally trying to find all the parts in my shop I had to buy to replace the stolen ones. Please tell me that 2 wheel drive 292 mounts will work on a V-8 crossmember that i have and i don't have to find an angled one or different brackets because I remembered wrong! And of course any pix of the crossmember, mounts and clutch linkage stuff would be great so i can match up what i have. Thanks, Steve |
02-02-2011, 09:30 PM | #2 |
Re: 292 4x4 engine crossmember questions...
As far as I know the cross member is the same for all engine its the engine stand ( frame mount ) that is different smblk bblk 250i6 292i6.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-02-2011, 09:43 PM | #3 |
ah......
Thanks steve |
02-03-2011, 01:20 PM | #4 |
The 292 engine cross member in the 4x4 is different than any other cross member. It is angled. I'm not sure about the 2wd 292 cross member. If your putting a 292 back in the truck you'll need a 292 4x4 cross member.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
02-04-2011, 12:35 AM | #5 |
any pix? lol I have wtb in the for sale forum, so we shall see
Thanks, Steve |
02-08-2011, 08:58 PM | #6 |
Ttt
02-08-2011, 09:12 PM | #7 |
i was under the impression that the cross member for a 2WD 292 was offset from one frame rail to the other. i'm hoping it's the same crossmember for a 4X, i want to drop the 292 into my 69.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
02-14-2011, 10:53 PM | #8 |
ttt
02-14-2011, 11:54 PM | #9 |
This is correct info. Good job Gary. If you look in my build thread you can see how the previous owner fabricated the V8 4x4 crossmember to fit the 292. My build thread is in my sig.
02-16-2011, 08:44 PM | #10 |
thanks
