Old 02-02-2011, 11:25 PM   #1
GMC Guy
GMC Guy's Avatar
things aren't adding up...
i'm really not sure what is reading inaccurate. i'd just like to know how fast i'm going lol
1. just replaced the speedo cable, re-greased, no more boucing
2. 28 inch tall tires, bfg 275/60/15
3. doubled checked rear gear ratio. keep coming up with 3.08
here's where i'm confused, when i use the RPM calculator, it doesn't match up with what my tach and speedo are showing me on the road. (new Auto Gage tach btw)
http://www.csgnetwork.com/multirpmcalc.html
according to my gauges, here's what i'm doing on the freeway:
65mph: about 2700 rpm
70mph: about 2850 rpm
75mph: about 3000 rpm
80mph: about 3300 rpm
these numbers don't add up with what i should be doing with 3.08's, but they are almost the same as the numbers for 3.42 gears...
sorry if i'm not making sense guys, just confused
just looking for anyone's advice on what isn't reading accurate, thanks ahead of time
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 02-02-2011, 11:37 PM   #2
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: things aren't adding up...
Most likely cause your tires arent actually 28" tall. Thats what they spec out to, but i bet, if you measure them, they arent actually that tall and are closer to 27".
y5mgisi is offline   Reply With Quote
Old 02-03-2011, 12:24 AM   #3
86k20mudddigger
Agreed^^
Plus them one leggers you always do dosent help the tire size either haha
86k20mudddigger is offline   Reply With Quote
Old 02-03-2011, 01:30 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
Keep in mind that the teeth on the speedo (in the tranny) need to match your gears and tires. There are different combos available and there are also reduction units that could go between your speedo cable and where it hooks to the tranny to help offset the tire/gear combo. I have a '78 and I also run 275/60/15 BFGs. My speedo is between 5 and 10 mph off.
Old 02-03-2011, 01:51 AM   #5
GMC Guy
GMC Guy's Avatar
how do i know what speedo gear to use?
th350, 3.08 gears, 28" tall tires.
and even if the tires were a little under 28" it wouldn't throw the speedo reading off by over 5mph
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-03-2011, 06:31 AM   #6
S10Fan
Old Heap Driver
Use a GPS to check your speedometer, have someone with you so you're not writing and driving. Make note of the GPS Vs Speedometer readings. Pull the speedometer gear out of the transmission, count the teeth, make note of the color, and check the color of the gear on the transmission shaft. Take all of that info along with your tire size and check with these guys................
http://www.transmissioncenter.net/sp...n_______va.htm
BTW.....I love my 700R.....70mph=2000rpm
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-03-2011, 08:30 AM   #7
xrcr
I was going to suggest timing between mile markers and checking tach and speedo numbers (distance/time=mph) 60mile pr hr= mile pr minute so 60seconds in minute x 60minute in hr = 3600 therefore 3600/60 = 60 mph
This won't help you dial in your guages but it will show you where you're at.
xrcr is offline   Reply With Quote
Old 02-03-2011, 10:41 AM   #8
Corts60
Just here to tinker
Corts60's Avatar
http://www.sccoa.com/faq/speedgr.html
here is another calculator link that involves speedo teeth...
Old 02-03-2011, 08:50 PM   #9
GMC Guy
GMC Guy's Avatar
ok, i borrowed my friend's garmin gps and took note of the speed readings of the gps vs. my speedo on the way to school. come to find that the readings are almost right on...my speedo is within 0-3 mph slow of the gps reading. this still doesn't explain my tach readings at the relative speed. they seem to be 200-300 rpm off (on the high side) of the given speed.
ex.
75 mph should be approx. 2850 rpm
but instead, at 75mph the tach is reading around 3050 to 3100 rpm
could my brand new $70 tach be off?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-03-2011, 09:12 PM   #10
71swb4x4
71swb4x4's Avatar
That's a silly question. Have you ever bought a new product that was defective? I think it's happening more and more. New doesn't mean it works right. So many people in this world are bent on the price they pay, and not the quality of the product. It's messing stuff up for the rest of us.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-03-2011, 09:20 PM   #11
S10Fan
Old Heap Driver
OK, I miss interpreted the original issue. I thought you were trying to tackle a speedometer issue.
Now that you know the speedometer is accurate I wouldn't be concerned with the Tach. Seriously, 200-300 RPM is probably as good as it's going to get for an inexpensive tach. Unless you're running a Pro-Stock 200mph race car 300 rpm doesn't make a difference.
There's an old saying in racing, "How fast can you afford ($$$) to go?".
"How accurate can you afford ($$$) your tach to be?"
Bryan
Old 02-03-2011, 09:39 PM   #12
GMC Guy
GMC Guy's Avatar
this is unfortunately true...
my problem is that my speed doesn't match what my rpm's should be with 3.08 gears and 28 inch tires.
but out of curiosity, i just went outside and measured my back tires from the ground to the top. they measured at approx. 26 3/4 inch...
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-03-2011, 10:49 PM   #13
f.monroe
f.monroe's Avatar
What trans are you running? Keep in mind that most calculators use a 1:1 ratio for drive. A manual trans or a trans with a lock up converter will give a true 1:1. A TH350 or TH400 without a lockup will probably still have slippage at highway speeds and is probably the 200-300-rpm you are looking for .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-03-2011, 10:52 PM   #14
GMC Guy
GMC Guy's Avatar
ohhhh that makes sense. lol i just have a standard th350 without lock-up. just can't wait to get my 700r4 installed with lock-up
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-03-2011, 11:10 PM   #15
y5mgisi
y5mgisi's Avatar
That adds up to alot! Have you re calculated it at that measurement?
Old 02-03-2011, 11:12 PM   #16
68longhorn
68longhorn's Avatar
f.monroe beat me to it! I was going to say the same thing, especially if you have a higher stall conv.
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 02-04-2011, 02:03 AM   #17
GMC Guy
GMC Guy's Avatar
does 26 3/4" seem normal for 28" diameter tires?
and as far as the stall rating on the converter, i have no idea. i doubt it's very high. is there any way of finding out?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-04-2011, 01:06 PM   #18
71swb4x4
71swb4x4's Avatar
Is the 26 3/4" with the truck sitting still and the tire squatting?
What you really should do is get an ex-girlfriend to hang out of the bed and measure it while you are driving down the road so you get a true measurement of the size while you are driving.
Old 02-04-2011, 03:33 PM   #19
GMC Guy
GMC Guy's Avatar
yes that measurement is with the truck sitting still.
and ya i wish
Greg
1974 GMC
L33 5.3/4l65e
.................__
