02-03-2011, 06:08 PM | #1 |
Advise on c-notch?
Going to do a bolt in c-notch and want to know what is the best way to go about it. Do I bolt it in then cut the frame or mark it, cut the frame then bolt it in? going to use an angle grinder with cutting wheel on it, and a step bit for the holes. any help would be appreciated! thanks Jim
71 chevy cheyenne lwb http://s321.photobucket.com/albums/n..._tab_my_albums Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote! |
02-03-2011, 06:19 PM | #2 |
Re: Advise on c-notch?
I believe you have to mark it, cut the frame, then bolt or weld it in.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
02-03-2011, 06:31 PM | #3 |
I bought my 3" c-notch pre made, it is a bolt on kit ( very easy and clean install ), i first took my shocks and springs out and rested the frame on the diff, made a center mark on the frame from the center of the diff, marked my pattern on the frame and cut it out with a grinder ( cutting wheel ) Then bolted in the c-notch. took me about 4hrs to do, hope this helps bud
1972 c/10 Custom, Long Box, 350 Small Block, Auto 3 Speed, Custom Wood box, Full Air Ride, 3" C-Notch, 20" Front & 22" Rear Tires, Snow White Paint, PT Crusher Handles, |
02-03-2011, 06:47 PM | #4 |
Kill Bill...et
First, jack the axel to the frame to find where it'll hit so you know where to place your notch. If it's a CPP notch, the instructions aren't always dead on.
Then, I made a cardboard template: Marked the frame: Cut...and don't forget to trim some of the spring reinforcing plate so your notch sits flush.: Refit, mark holes, spend half the day drilling said holes...paint. and bolt on! Enjoy!...Actual results may vary. and don't forget about tool safety! |
02-03-2011, 09:15 PM | #5 | ||
02-03-2011, 10:18 PM | #6 |
Happy to be here
Go buy a quality uni-bit and some good cutting oil. Your going to be a while.
02-03-2011, 10:24 PM | #7 |
will do. thanks all for your help!
02-03-2011, 10:58 PM | #8 |
67-72 parts collector,…
Several suspension Vendors sell these bolt-in c-notches.
Here's a few: * Classic Performance Products * Performance On Line * McGaughy's Suspension I prefer the new bolt in notch from www.PorterbuiltStreetRods.com. (It's listed in the "mild" rear drop kit,... but I assume it can be purchased seperately)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-05-2011 at 09:05 AM. |
02-04-2011, 03:23 AM | #9 | |
Kill Bill...et
Oh yeah...mine was a cpp notch. Last edited by stevencvn72; 02-04-2011 at 03:24 AM. Reason: I forget everything. |
02-04-2011, 09:08 AM | #10 |
anyone have a brand name of a quality bit?
02-04-2011, 09:36 AM | #11 |
forget what the super-builders from Discovery channel uses and save yourself some cash by just using good sharp regular twist drills ... there is a reason they've been in use for over 150 years in metal-working circles
02-04-2011, 11:07 AM | #12 | |
It doesn't get much better than "Klein". All their stuff is top notch professional grade. Quote:
It's ok to embrace new technology when working on old stuff.... really, it is. Last edited by N2TRUX; 02-04-2011 at 07:57 PM. |
02-04-2011, 02:33 PM | #13 |
uni-bits are what you call new technology?
02-04-2011, 03:35 PM | #14 |
Well, 'newer' than twist style bits .
02-04-2011, 03:48 PM | #15 |
point taken ... then again, bicycles are "newer" than horse and buggy too.
anywhoo ... step-drills (uni-bit style) are designed to enlarge already existing holes (not creating new holes) in material less than 1/8" in thickness. p.s. i'm fairly confident he doesn't want to debate me in the subject of new technology and metal cutting. Last edited by Shane; 02-04-2011 at 03:49 PM. |
02-04-2011, 03:52 PM | #16 |
needs more $$$
I've never owned "quality" drill bits...just craftsman stuff so I can't really say the unibits are better than good regular bits. Although, after I bought my cheap unibits from harbor frieght, I'll never try to drill through a frame with a regular bit again. I use them from from start to finish (no pilot hole) with great results. They don't really walk on you when not using a punch either, but I still use one 95% of the time.
I have broken a couple of them (usually my fault for going at an angle at the start)l, but given they are from Harbor Frieght, it's cheap enough to replace without me being too angry about it.
1970 2wd Blazer |
02-04-2011, 07:12 PM | #17 | |
Thus far you are the stand alone when it comes to recommending twist drills, for this application. Do tell us though, how would you do this? Let's say you want to end up with multiple 9/16" diameter holes in a Chevy Truck Frame that is 0.160" thick and you were using a common hand held 1/2" drill motor like a Makita or Dewalt and a cardboard template showing where the holes go. Give us the step-by-step Shane's how to. Last edited by lakeroadster; 02-04-2011 at 07:57 PM. |
02-05-2011, 08:44 AM | #18 |
not sure if its just me or not.... but ive come to notice that on many threads started by others, SHANE tends to get into a battle of words with people.
this thread started with a guy looking for advice or ideas, and is ending up with a debate on drill bits. good luck with the notch man. i was gonna try this on my 85. but ended up having a buddy do it for me. well he is in the works of getting truck lowered for me. shoulda kept it and tried it on my own. but didnt want to mess anything up and be with out the truck. good luck man. |
02-05-2011, 08:50 AM | #19 |
Anyone else?
02-05-2011, 02:24 PM | #20 |
i just put my c notch in...
http://67-72chevytrucks.com/vboard/s...d.php?t=443217 the cpp notch went in great. even with the lil mods i had to do to make it fit it was still a real straight process. all the things mentioned above are spot on as far as how to do it. and esp the drill bit talk. one thing that helped me, dont laugh, but i never put the support handle on any of drills, and i put it on towards the end and it was soo much easier. doesnt wanna twist out of your hand nearly as much. i wonder if thats what they designed it for hmmmm haha |
02-05-2011, 02:27 PM | #21 |
There's more than one way to successfully complete the task of drilling holes in a frame. I like using unibits when boring large diameter holes (over .500"). I tend to use regular bits on smaller holes.
And yes.... that handle makes it much better on the wrists .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-05-2011 at 02:28 PM. |
02-05-2011, 05:12 PM | #22 |
great tips! going to order a step bit and have 4 good twist bits for back-up thanks for all the replys! without this site i would not have had the confidence to do half of the stuff i do to this truck!!!
02-05-2011, 08:07 PM | #23 | |
02-05-2011, 08:10 PM | #24 | |
2.) pilot drill with a 9/32" twist - preferably one with a 118º split point 2.) then drill the hole to finish size using something similiar to this. http://www.fastenal.com/web/products...u=53953&ucst=t next question? Last edited by Shane; 02-05-2011 at 08:15 PM. |
02-05-2011, 08:18 PM | #25 | |
Either type drill (twist or step) will work once you have your pilot hole there. Hope this helps. |
