![]() Join Date: Sep 2009
master cylinder
when useing a power booster do you need a master cylinder for power brakes or are they the same as manual. i bought the front end from Delmo and need a master cylinder for disc -drum
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: master cylinder
You need to use a power style master with a brake booster. The manual brake masters are different where the pushrod makes contact. Some of the manual masters have the pushrod attached. Don't forget a proportioning valve.
