Old 02-03-2011, 10:31 PM   #1
4x4toy
headlight adjusters, correct fit
Hi all,
Looking for a source for correct headlight adjusters for my 85 with 4 headlights. I have replace the broken originals with Napa replacement crap. Did not fit well and stripped when I adjusted the light positions. My GM parts guy said "not available anymore". Who has NOS for sale or the correct restoration part for my truck. Tired of the Chinese Junk!!!!
Thanks.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 02-03-2011, 10:55 PM   #2
str8axle55
Re: headlight adjusters, correct fit
I know LMC, and Dorman makes them, not sure on the quality. I need some for mine, running plow lights for the winter.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 02-05-2011, 11:11 AM   #3
4x4toy
Bump
Old 02-05-2011, 12:04 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Even back in the 80's we did not buy those adjusters from GM, we got them from our nut and bolt suppliers in bulk. The aftermarkets we used were identical to the OE parts and a fraction of the cost. Call a local body shop and ask them who is their nut and bolt supplier and then go contact them.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 02-05-2011, 01:06 PM   #5
DREAMER1
DREAMER1's Avatar
When I changed my grill on my 85 to 91 the adjusting nuts/fastener were stripped an I spent an hour at oreillys trying to find a replacement. When I went home my buddy ( fellow square body) took one look at it and fixed it by placing a nut behind the fastener where the bolt barely poked out and tightened the nut instead of the fastener itself. It isn't OE, but it definetly did the job
DREAMER1 is offline   Reply With Quote
Old 02-05-2011, 02:59 PM   #6
SBTork
Garage wrench
SBTork's Avatar
goodmark industries sells them FYI
Also, GM does still sell them. You have to buy them in quanity though...
Nut, 365270 List $1.38 ea
Screw, 15705372 List $1.46 ea
Spring, 459461 List $2.85 ea
hope that helps....
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-06-2011, 07:30 AM   #7
4x4toy
SBTork, Thanks for the part numbers. I will order them Monday with my other part I need for 05 Sierra. I guess my my GM guy wasn't in the mood to look for them. Now all I need are GM tail lights and front turn and side markers and I will be happy.
Old 02-06-2011, 10:07 AM   #8
95 S_Trucker
95 S_Trucker's Avatar
i used the dorman ones on my 85, i also had the quad headlamp setup.
if you adjusters are stripping, your springs could be getting stiff or rusting together
95 S_Trucker is offline   Reply With Quote
Old 02-06-2011, 10:10 AM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
you used to be able to get them through a company called Motormite under the Help name in most auto parts stores
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-06-2011, 12:38 PM   #10
SBTork
Garage wrench
SBTork's Avatar
I don't have part numbers at the ready for the taillamps and side markers but I know the side markers are still avail. and the tail lamps are if you don't want the ones with the stainless trim, otherwise they're long gone....
-Adam
Old 02-06-2011, 09:03 PM   #11
qu1cks1lver56
qu1cks1lver56's Avatar
i buy the crap replacements, then use my tap & die set and rethread the screw to fir a nylock nut and use a washer on the back of the core support, no more plastic stripping out.
qu1cks1lver56 is offline   Reply With Quote
Old 02-14-2011, 10:16 PM   #12
4x4toy
Thanks again SBTork, Replaced my adjuster with the GM pieces and adjusted the headlights. What a difference, I can see now. GM adjusters fit perfectly and adjusted with out any issues. Now for Hella conversion and relay harness.
Old 02-14-2011, 10:34 PM   #13
SS Delux
SS Delux's Avatar
I am pretty sure that you can get replacement tail lamp lenses from parts source or O'Riley for like 16 bucks each (IIR they have the chrome trim too). Looking foreward to the Hella conversion, keep us posted.
SS Delux is offline   Reply With Quote
Old 02-14-2011, 10:51 PM   #14
SBTork
Garage wrench
SBTork's Avatar
no problem man, just glad to be able to help.
-Adam
Old 02-14-2011, 11:44 PM   #15
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
The ones from napa work, you just cant have tension on the when you adjust them. I just guess where they should be, carefully put the spring on and to adjust i remove the spring and lossen or tighten them. i did them on my truck a year ago and they are still good.
"san diego chargers #1"
joe1982 is offline   Reply With Quote
