Old 02-04-2011, 12:00 AM   #1
scum1
scum1's Avatar
Control arm questions
Heres some pics of my control arm and bracket that bolts to the frame and crossmember..couple questions. 1st are all those shims on the uca normal, is that for alignment? should i reassemble the same way?
And 2nd you can see that there is a bolt missing in the bracket to the frame. it is the same on the other side. it doesnt exactly line up on either side, should i drill it out and bolt it up?
scum1 is offline   Reply With Quote
Old 02-04-2011, 12:44 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Control arm questions
The shims are there for alignment... quite common on the C10s. It looks like somebody installed a crossmember from a later model... that would explain the holes not ligning up. Drill some holes and install the missing bolt while you have the suspension apart.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-05-2011, 01:30 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks like possibly a 71-72 crossmember.
(notice the steel brake line tab, on the front side of the crossmember)
I see the long rubber brake hose now connect through a hole in the frame,... similar to the 73-87 trucks.
Keith
Convert to disc brakes.
