Old 02-04-2011, 02:40 AM   #1
skoffice
skoffice's Avatar
Ok I may need some serious thinkers..
Can a guy put one of the newer 6L80E transmissions behind a Gen III, running cable throttle, on an 02 computer? Is it possible? The first thing I can think of is that the computer just would not be compatible, apples to oranges. But you can virtually tune these computers to do anything you want right? I know the computer would have to be pinned for the different trans but I am not afraid of that. I'm not sure I'm going to do it yet, but if I did find a deal on the 6L80, I would swap it for my 4L65 in a heartbeat. Any thoughts!?
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-04-2011, 11:30 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Ok I may need some serious thinkers..
I wanted 6 speed, but my budget said different.
Some info here, good luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=422550
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-04-2011, 11:46 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The way I understand it, which could be wrong but on the newer 6speed autos, the PCM doesnt control the trans the TAC module does and the TAC and PCM dance together.
A 2002 PCM wont have the TAC module, you would need to upgrade your DBC to DBW and get the PCM, TAC and BCM (I think) for the year/model of the trans and have them all tuned for each other. Might not be cost effective but would be cool.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-04-2011, 11:36 PM   #4
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
The 6 speed has a separate computer, and the pcm for the late motors uses a 58 tooth reluctor input where the 2002 pcm is a 24 tooth. It may be possible to run the 24x motor with the late pcm, But I am not sure if it would still communicate with the trans computer. So I guess my answer is I am not sure of an easy way and there isn't going to be a cost efficient way. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-06-2011, 07:26 PM   #5
Juiced06GTO
Easiest would be to get the tci or compushift controller to run the 6l80 and let the pcm run the motor.
Juiced06GTO is offline   Reply With Quote
Old 02-07-2011, 02:03 AM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
....or try the M-90 from Mast or some of the other aftermarket ECM's...that have the capability to run a 6 speed.
Keep in mind TCI now sells their own 6 speed and controller.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
