Old 02-04-2011, 10:36 AM   #1
FL71C10
Spark plug wires with HEI and headers
I am putting the motor in my truck and need some new spark plug wires. I have a 350 with an HEI distributor and headers. Should I use 90 degree plug boots, or what? I think it would make sense to get a universal kit that I can tailor the length of the wires, but wasn't sure about the boots.
Any suggestions would be appreciated!
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-04-2011, 11:08 AM   #2
Lee H
Lee H's Avatar
Re: Spark plug wires with HEI and headers
I have a very similar set up. I'm running MSD part number 31763. I run them down the back side of the block, across near the oil pan and up to the plugs. I run the front two between the block and the motor mounts. Keeps them out of the way and looks clean.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-04-2011, 11:13 AM   #3
FL71C10
So they run behind the headers, or underneath?
Old 02-04-2011, 12:21 PM   #4
kaycee
kaycee's Avatar
I run wires from NAPPA that are for a 74 vette 350 and run them down behind and under headers,just like LEE said
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 02-04-2011, 01:12 PM   #5
FL71C10
So the spark plug boots are 90 degree angle ones?
Old 02-04-2011, 01:40 PM   #6
MARKDTN
I used stock '76 truck Delco wires on 1 I did. No issues.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-04-2011, 04:06 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
They have to be... or you'll burn them on the headers regrdless of which way you route them.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-05-2011, 11:08 AM   #8
kaycee
kaycee's Avatar
Yes they are 90degree boots
2005 FXDWG stage3
63 IMPALA 327
Old 02-25-2011, 12:27 AM   #9
FL71C10
Lee H,
Thanks for the tip. I ordered those wires from jegs and put them in tonight. They fit great. Almost ready to start it up!
Old 02-25-2011, 12:23 PM   #10
Lee H
Lee H's Avatar
Your welcome. Hope all goes well with your build. One extra tip, keep the number 5 & 7 wires separated. As they fire next to each other in the firing order they can cross fire causing an annoying miss.
Old 02-25-2011, 12:50 PM   #11
cdowns
cdowns's Avatar
i like cut to fit wires from taylor and the sets i've used came with both 90's and straight boots so you can use what works best
Old 02-25-2011, 03:25 PM   #12
kcsa75
kcsa75's Avatar
Back in the day, silicone plug wires were strongly recommended with headers because of the added heat. Is that no longer the case or do all of them have silicone jackets?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 07-28-2012, 10:09 PM   #13
dropanddrag71
dropanddrag71's Avatar
I need wires asap. I am running a Chevy small block with headers.. I notice some boots are straight and some are 90 degrees... I want to run them over the valve cover, can i still use 90 degrees on all eight?
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying"
dropanddrag71 is offline   Reply With Quote
