02-04-2011, 12:44 PM | #1 |
do i need this?
I plan on lowering the front with bags and drop spindle. Currently, my lower arms are missing this piece. Do i need them?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
02-04-2011, 01:08 PM | #2 |
Re: do i need this?
No, it holds the bump stop. A lot of people run with no bump stop or they install a bump stop directly to the A-arm.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
02-04-2011, 01:12 PM | #3 |
67-72 parts collector,…
Re: do i need this?
Not really.
That's the steering stop for the spindle. The long "slot" on top is for the rubber snubber,... that you no longer need.
02-04-2011, 02:26 PM | #4 |
A guy with a truck
Re: do i need this?
...and would probably rub your bags...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-04-2011, 09:16 PM | #5 |
Life, Be In It.....
Re: do i need this?
What would or have you done to remove them?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
02-04-2011, 10:23 PM | #6 |
Happy to be here
Re: do i need this?
They are spot welded on. You can use an air chisel to remove them.
02-04-2011, 11:25 PM | #7 |
Re: do i need this?
Would you need to remove that pc with 2.5 drop spindles and 1 or 2 " drop coils? Or would you be ok and not rub?
