tonneau cover with cage?
im thinking about making a tonneau cover for my bed out of aluminum sheet metal. i have a design on how to support it and so its removable and stuff, only problem is what should i do if i have two tubes welded out the cab into the rear frame. how do i make it go around?
Re: tonneau cover with cage?
something like this
That will be awesome...just dont have any idea how..good luck ![]()
![]() 1953 BBC 3100 427 T-400 12 Bolt ![]() ![]() Al |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You're going to have to have a joint right where the rear tubes pass thru the cover. You will have to make either half round notches, or longer slots for the tubes. Depends on how the joint lays in relation to the tubes.
If you want the cover to be removeable it will have to be a couple piece. If you made a 3 piece cover and brough the tubes in at a joint between the first two panels it would be fairly easy. Just notch each panel in a half moon where the tube goes through and call it good.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
thats what im planing on doing only im gonna make 5 panels because mines a longbed ill post some pics when i start making it
Justin weight 3480 with driver 1.35 60ft 6.13@111mph 1/8 mile 9.80@131mph 1/4 mile 434 small block all motor |
What thickness/grade of aluminum should be used? Or should it be steel?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 02-06-2011 at 10:27 AM. |
I have a vinyl cover that i'm going have to have stiched with snaps when i do my cage. I think it would look better than aluminum
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
![]() Join Date: Jul 2009
That is a great looking truck, were could I find more pics./info on it? I am looking for ideas etc... for my build.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
#12 | |
http://www.treetimekennels.com/FILE%...ACING/race.htm |
#13 |
I have a few pics in my build thread of my cover build.
http://67-72chevytrucks.com/vboard/s...151718&page=18
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#14 | |
i want it level with the top of the bedsides and still be removable. can you give me some details how you went about doing it? thanks |
#15 |
#16 |
A friend that owns a sign shop helped me build mine. Its made from black sign blanks that were cut into sections and bent for strength. It has some square tubing for added strength. Its removable but not very easy. The rear section flips up to access the fuel cell, batteries and fuel pump.
#17 |
#18 |
hows the cover coming
#19 |
#20 |
if you have the tubes come down at the correct angle (unless set by rules)
you can have a cover that lift up as the hole follows the angle of the tube.. make it like this and 2 piece flanged at the holes center line, and you'll have a removable and lift up (with hinges, like gaylords) to make it easy to load and unload at the track, or for parts runs, and still come off for servicing or if you need to load something taller than the bed sides.. note holes may need to have a little bit of an oval shape to them, but. you'll have a hinged cover that comes off if need be Last edited by stich626; 02-21-2011 at 04:21 PM. |
#21 | |
#22 |
This guy use to make custom covers I'm not sure if he still does.
http://s10dragracer.com/TravisBurney.htm
#23 | |
