02-04-2011, 03:59 PM | #1 |
4-6 Drop>need to be lower<
I put 4.5" drop on the front with 255/60 and 6" drop in the rear with a 275/60. Thinking it needs to be lower,Front fender is at 27.5" rear is at 29" want to drop it one more inch in the rear.what do you guys think ?
02-04-2011, 04:18 PM | #2 |
Dave's not here, man
Re: 4-6 Drop>need to be lower<
I think it looks great the way it is. I would just drive the crap out of it if it were mine. Do you have a notch in the back as it is? You could go a 1" block in the rear, but I'm almost certain you would need a notch if you don't already have one. Any pics of the motor? Beautiful truck!
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 02-04-2011 at 04:19 PM. |
02-04-2011, 04:22 PM | #3 |
I also really like that stance thats a hella nice truck you got there.
Trevor "You already said spite" |
02-04-2011, 04:24 PM | #4 |
I agree, I like it the way it is. I think if you go another inch in the rear you have to c-notch it.
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. |
02-04-2011, 04:36 PM | #5 |
2WD Jimmy
[ want to drop it one more inch in the rear.what do you guys think ?[/QUOTE]
Dont... these trucks were designed to have a small rake, without the rake they dont drive as well. Ask a qualified alignment shop and they will tell ou the same thing. |
02-04-2011, 04:48 PM | #6 |
Junior Member
make a block & do a small pipe notch. cheap & easy.
I think it needs to come down a bit more in the rear also
frontstreetcycle on Instagram |
02-04-2011, 04:56 PM | #7 |
"the other guy"
just roll around with a full tank ALL the time, should yield another inch or so
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
02-04-2011, 05:02 PM | #8 |
I put 1 inch block on my 6 inch drop(making it 7 inch). My truck is not on the road yet, but it dont look like ill need a notch. I was prepared to put a notch in there from the beginning, but im going to try it and see what happens first. I think it would look a little better with a 1 inch block myself. You just have to ask yourself if it is worth putting a notch in if you have to. Truck looks awsome the way it sets to though!
02-04-2011, 05:02 PM | #9 |
Noo .. looks great. I'd leave it
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
02-04-2011, 05:09 PM | #10 |
I had the same thought about mine, I used coil overes and it did not sit as low as I had thought. I drove it around for a while with the rake and liked it but still wanted more.
The first pic is of it with the rake at about 4.5 front and 4.5 in the rear The second is of it lowered at the 4.5 front and 6 rear. still has a bit of a rake which I like. My advice is to make it the way you like it because you are the one who is going to have to drive it.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
02-04-2011, 05:28 PM | #11 |
ok the truck just is 6" spring no c-notche. just got off the phone with stan at Early classic he said he can get me a 1" block for the rear next week,so we will see. took a few more pictures of the truck.still have along way to go have the Seats out now at the upholstery shop.I hope in the next few week I can pull the motor and trans for the LS1
02-04-2011, 05:43 PM | #12 |
needs more $$$
Looks great! I say drop it more...from the looks of it, you might have to re-do your exhaust after the axel though...it's already right on the super trac bar as is. I recommend a c-notch too...bottoming out sucks.
1970 2wd Blazer |
02-04-2011, 05:45 PM | #13 |
I say..c-notch it and lower it some more. Good looking truck btw.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
02-04-2011, 06:04 PM | #14 |
I knew that there was going to be more work on the exhaust when we put the 9" in,so we put a clamp at the rear of the mufflers
02-04-2011, 06:17 PM | #15 |
I think it looks great as it sits. It's all about what you want though. You also need to keep in mind that the springs will settle as you drive it. That's the good thing about blocks. If it's too much, just pull the blocks back out.
02-04-2011, 08:56 PM | #16 |
Junior Member
throw some weight in the back for now & see how it looks lower...
02-04-2011, 09:55 PM | #17 |
67-72 parts collector,…
Great looking truck.
Add a 1"-1.5" lowering block and a bolt in c-notch.
02-04-2011, 10:41 PM | #18 | |
Tot Roddin'
Don't forget about longer u-bolts... you will need these if you add the block.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-04-2011, 10:45 PM | #19 |
Moderator
If you go with a 7" drop, you will need a c-notch. I just dropped my truck 6.5" in the back, and it is only 1/2" from hitting the frame. It bottoms out routinely. I have a c-notch kit, just waiting on some time to install it.
I think your stance is perfect. I prefer a slight rake myself.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 02-04-2011 at 10:46 PM. |
02-04-2011, 10:59 PM | #20 |
Tot Roddin'
If I remember correctly... on my 4.5/6" drop I was 2" from the frame rail and 4" from the top of the pumpkin to the bed floor. For me, 1" travel wouldn't be enough to separate me from good/bad ride.
What about bags? Change the level you need for fairly cheap.
02-05-2011, 12:01 AM | #21 |
Thanks for all the help.frist I thouth that I could just put a one inch block in and be ok,then I was thinking about the c-notch and the block,then scrapmetalart said that I sould put some weight in the back for now & see how it looks.it all sounds,to good.I never even thought about the top of the pumpkin to the bed floor.72BlckButy brings up the bags I never thouth I would ever run bags.
02-05-2011, 12:03 AM | #22 |
Tot Roddin'
Trust me... once you go 4/6, then it's only "just" a few more inches, then it's bags, Dropmembers and then you're scrapping crust of the earth.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 02-05-2011 at 12:04 AM. |
02-05-2011, 12:06 AM | #23 |
like I said,I never thouth I would ever run bags
02-05-2011, 12:27 AM | #24 |
Bags can easily replace the rear coil springs, and allow you to carry heavier loads, pull a trailer,... whatever.
Many members use them with just two air lines and two schrader valves. No way to scrape pavement, with this set-up,... but a very easy way to adjust your ride height. Add a small tank and a compressor and adjust the height from inside the cab.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-05-2011 at 12:27 AM. |
02-05-2011, 01:52 AM | #25 | |
Looks GREAT the way it is!!!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
