02-04-2011, 04:40 PM | #1 |
Will 98 chevy wheels temporarily fit on my 68?
I have a flat on my 68 and the spare is flat too. I do have a set of 16 inch 6 lug wheels off my 98 chevy truck. Will they work just to keep the 68 moving?
02-04-2011, 04:43 PM | #2 |
its all about the +6 inches
Re: Will 98 chevy wheels temporarily fit on my 68?
the steel ones fit best, the alluminum ones may be a tick too wide if in the front.
They'll go on fine, but will be a total pain to remove (esp the silver steel ones) just like when on the 98 |
02-04-2011, 04:43 PM | #3 |
Depends on which wheels. They "might". Check depth, bolt pattern, and hub fit.
"Did you seriously just ask me what I need more power for?" "You're stupid, cause I've smoked plastic." Last edited by actconstruction; 02-04-2011 at 04:45 PM. Reason: Had two forums open at the same time and posted to the wrong one (user error). |
02-04-2011, 07:06 PM | #4 |
Car Knocker
Do you mean as till you get something else or do you mean temporairly till they fall off . Sorry couldnt help it. Someone will help ya I am sure. BTT
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
02-04-2011, 10:10 PM | #5 |
to add to my comment... I have run the silver steel wheels on my one ton. I KNOW they'll work.
