Old 02-04-2011, 05:41 PM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
4x4 shock mounts 72 and also later 3/4t trucks
so my 72 K5 has 76 or so 3/4 ton axles under it. its got a 4" lift as well. so I'm trying to track down the reason now, shocks for Any 72 4x4 1/2 3/4 or 1ton rough country has i think the 9102 listed for it. ANY 73+ truck it lists a 9106 i believe. looked at the specs and it is taller fully extended. I already got the 9102s and they are damn near fully extended mounted. i think I'm just goin to relocate a shock mount to center the travel at ride height.
but I'm curious and kinda lookin for pictures of where on the frame and on the axle shocks mount on
*72 1/2t or k5
*72 3/4t
*73+ 1/2t
*73+ 3/4t
anyone help me out? I guess it really dont matter for sure, the shocks I got are deffinatly too short and i gotta change it but just kinda wondering. or if anyone has any suggestions, SHORT of telling me to buy the longer shocks
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 02-04-2011, 07:04 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 4x4 shock mounts 72 and also later 3/4t trucks
Maybe it is because in 68-72 the shock mount on the axle housing is shorter than the 73 up ones? I had the same issue on an old 69 K10 and ended up putting on the later shocks. As far as I know the shock mounting location on the frame is in the same place. I could be wrong though.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-05-2011, 06:40 AM   #3
1malo68
1malo68's Avatar
I'm not exactly sure what you're looking for but here is a pic of a 72 K10 frame with a 79 3/4 ton 10 bolt front axle
1968 K10/30
Frame Off Project "Overkill"
My 5 year, $30,000.00 toy
1malo68 is offline   Reply With Quote
Old 02-05-2011, 04:22 PM   #4
OrrieG
OrrieG's Avatar
I had the same problem when I put the 74 axle under my 59. I fabbed the top bracket then measured the distance with the engine, etc. in. Then I went to local 4wd place and started measuring shocks fulled compressed and fully extended and bought one that had center matching my measurements.
OrrieG is offline   Reply With Quote
Old 02-05-2011, 11:27 PM   #5
mstrav1973
mstrav1973's Avatar
If you have a 4" lift, you must buy shocks sized for the lift. I have 72 with a lift and had no problems finding shocks. I used the bilsteins as they have specific shocks for my truck / lift combo, but there are other choices out there.
stock length shocks will be maxed out!!
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 02-06-2011, 12:03 PM   #6
chevy2racr
chevy2racr's Avatar
the 9102s that i got are for "72 k5 2"-4" lifts"
71 C10 with 454
09 Malibu
Marshalltown, Iowa
