02-04-2011, 11:20 PM | #1 |
smoke coming from oil filler
hi on my 67 350 there is smoke coming from oil filler & a little oil. do i need a rebuild, rings or head work? diffent kind of oil? the truck runs great is just the smoke is bothering me I only notice the smoke when I open the hood
02-05-2011, 04:49 AM | #2 |
Re: smoke coming from oil filler
Kind of odd, how often do you drive the truck?
02-05-2011, 06:35 AM | #3 |
Make sure that your PCV valve is functioning properly and that the vacuum line is not plugged.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-05-2011, 08:59 AM | #4 |
My guess is this is going to turn out to be a leaking valve cover that is leaking onto the exhaust. Never seen an oil filter get so hot it would smoke.
Posted via Mobile Device |
02-05-2011, 09:12 AM | #5 |
With the smoke coming out with some oil, sounds like you maybe gonna have a rebuild in your future? Just my $.02.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
02-05-2011, 10:28 AM | #6 |
It's called blowby. Your rings are going away. All motors have a little blowby. A good pvc system will help reduce it.
02-05-2011, 11:03 AM | #7 |
Geezer is right on. What weight oil are you running? Do you have a PVC hooked up. The PVC will not reduce the amount of blow by but will send it back to the motor to be burned VS letting it go into the atmosphere. If it's running good and still has power I'd switch to some heavier weight oil to buy you some time. Watch your oil consumption. If your only going through a quart or so between changes then no worries. In Cali I would not hesitate to use some 20-50 in that thing.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-05-2011, 12:07 PM | #8 | |
Posted via Mobile Device Last edited by camaney; 02-05-2011 at 12:09 PM. |
02-05-2011, 12:46 PM | #9 |
02-05-2011, 03:37 PM | #10 |
ok so the pcv works good. what's the numbers on compression test? the truck has been off the road for a least 10 years that I know.
02-05-2011, 04:16 PM | #11 |
The numbers are not so important as the consistany between the cylinders. You'll want the high and low to be within 10% or so of each other. While a compression test will give you some indicators, a leak down test will pin point exactly what's going on with your engine.
02-05-2011, 07:03 PM | #12 |
Ok. so i did the compression test & this is what I have 1-150 2-150 3-80 4-135 5-145 6-150 7-150 8-040 that wet and dry testing no change at all what do you think
02-05-2011, 08:37 PM | #13 |
Car Knocker
If your readings are correct. Number 3 and 8 have either a burnt valve or bad ring set in them. My 2 cents. Drive it till it quits, or you get tired of putting oil in it. Whatever comes first. Most of all, have fun with it, might be a chance to do a little upgrade on the drive train.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
02-05-2011, 08:49 PM | #14 |
I think your engine needs a rebuild. #3 and #8 are definately your problem. most likely stuck rings. You could try some marvel mystery oil or some other similar product. With the engine sitting for that long thats the most likely cause. From the compression numbers the rest of the engine looks fairly healthy. I would try a few of the miracles in a bottle and then just yank it out and start over.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-07-2011, 04:38 PM | #15 |
Thanks every one I'll be using one of those bottle thingys & see how far I can go like this
