02-05-2011, 12:06 PM | #1 |
paper or plastic?
Stock Steel Wheels
I'm new to the 67-72 trucks Any have a question. I just bought a 67' and am doing the disk brake/lowering but I want to keep the stock 15" wheels w/hub caps. From what I've read the stock wheel wont clear the new brakes. So, what wheels will ? Will they match the rear? Will the hubcaps fit?
Thanks for any input!!
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
02-05-2011, 12:33 PM | #2 |
Re: Stock Steel Wheels
I don't know about clearance, but your main problem is the stock 67 wheels have six holes and most of the disc brake swaps require wheels with five holes.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
02-05-2011, 12:40 PM | #3 |
67-72 parts collector,…
Are you using 5-lug oem rotors or aftermarket 6-lug rotors?
02-05-2011, 12:40 PM | #4 |
I guess you're doing an aftermarket disc brake conversion. The 4wd disc brake truck ('71-up) wheels will do ya in both rear clearance and hubcap fit. Blazers and K/10 Suburbans up to '91 ran them. Although rallyes and alloys pretty much took over by then.
My '85 Jimmy has what you are looking for:
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-05-2011 at 12:43 PM. |
02-05-2011, 12:43 PM | #5 |
Any 71-87 2wd steel wheel will work with 5-lug rotors.
Any 71-87 4wd steel wheel will work with the 6-lug rotors. The 60-70 steels wheels don't have enough clearance on the backside, for the disc brake caliper.
