Old 02-05-2011, 02:42 PM   #1
J-Rod#7
J-Rod#7's Avatar
Question Need Intake Advice, Please!!!
I'm dropping an ls2 (blown to a 427 ) in my '68 sidestep, and Ive been searching high and low for a really good EFI intake manifold. I was wondering if anyone had any suggestions on what would be the best intake manifold for this type of app?
I'm building it to go to the track, so horsepower is the main concern here.
Thank you for all and any suggestions.
J-Rod#7 is offline   Reply With Quote
Old 02-05-2011, 10:37 PM   #2
85burb
85burb's Avatar
Re: Need Intake Advice, Please!!!
Holly has a new set of maniflods out for the LS motors, other then that there is the fast. You can get up to a 102mm throttle body. I am assuming you are going EFI.....
http://www.holley.com/SEMA/Pictures/...adquarters.pdf
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-05-2011, 10:44 PM   #3
clinebarger
Have you checked out the FAST 102MM intake? http://www.compperformancegroupstore...Category_Code=
clinebarger is offline   Reply With Quote
Old 02-06-2011, 07:13 PM   #4
Juiced06GTO
Fast is the way to go thats what i Run on my GTO
Juiced06GTO is offline   Reply With Quote
Old 02-07-2011, 12:09 AM   #5
skoffice
skoffice's Avatar
I like the carb super victor intake with a Fast dominator 4 barrel throttle body and injectors. Go speed density.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-07-2011, 11:47 AM   #6
Shon
how much boost?
Lots of guys run the FAST style intakes but some with high boost numbers will run the BBK/SSI intake made out of aluminum.
What TB set up do you have: ie throttle cable or drive by wire?
If you have room and under a truck hood you do, the Edelbrock Vic Jr or Super Vic for EFI is a nice route, which you can nearly by all new parts for less than a used FAST intake and TB set up.
What ever you need I probably can help.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
