Old 02-05-2011, 04:16 PM   #1
zackary027
zackary027's Avatar
Dual Electric Fans
i have two electric fans i found in my shed hooked them up and they both work the only problem is one blows and one sucks. will a setup like this keep my truck cool, or do i need to find a way to make them both suck. i have no ac just a peppy 350. have aftermarket tranny cooler also.
zackary027 is offline   Reply With Quote
Old 02-05-2011, 05:16 PM   #2
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: Dual Electric Fans
You should be able to take the blades off one of the motors and turn it around making it blow the same direction as the other. Which direct depends one where you plan to put the fans. But you always want the fans to pull cold air into the engine bay, so if you mount the fans on the front of the rad you want the fans to push, and if you mount the fans behind the rad you want them to pull.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 02-05-2011, 07:07 PM   #3
joe231
joe231's Avatar
They are DC motors, just reverse the positive and negative to make them turn the same way. Or put one in front of the radiator and one behind it.
CHEVY ONLY
