Old 02-05-2011, 04:51 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
C35 front brakes
The front brakes on my dually feel a bit "grabby" but not when you lightly put the brakes on but when your nearing your stop. it's not affecting my ability to stop. but was never like this before it was parked for about a month or so.
any one ever ome across this? Also the front Pads have lots of life on them.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 02-05-2011, 09:59 PM   #2
wyattglock
wyattglock's Avatar
Re: C35 front brakes
I have the same problem on the opposite end. If the truck sits for even a couple of days the rear brakes will be grabby for about 3 or 4 stops. Then it goes away and it is fine as long as it is driven daily. I am kind of wondering if the proportioning valve is freezing up or something.
wyattglock is offline   Reply With Quote
Old 02-05-2011, 11:12 PM   #3
SCOTI
SCOTI's Avatar
Surface rust on the rotors causes them to work as if freshly turned w/a rougher surface. More friction = more bite.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2011, 11:51 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
So nothing to worry bout?
Old 02-05-2011, 11:59 PM   #5
SCOTI
SCOTI's Avatar
Typically returns to 'normal' once a few miles have passed & the brakes have been cycled a few times to knock the surface rust off.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
