Old 02-05-2011, 04:54 PM   #1
haplis
ignition switch replacement
ok so does anyone know how to replace the ignition switch on a 68 c10, ordered the new one but cant seem to figure out how to remove the old switch. any help would be appreciated. i will post some pictures in a little while. thanks again
haplis is offline   Reply With Quote
Old 02-05-2011, 05:32 PM   #2
67sss
67sss's Avatar
Re: ignition switch replacement
put a paper clip in the little hole on the switch, turn it-can't remember which way- and the tumbler will come out.
67sss is offline   Reply With Quote
Old 02-05-2011, 06:19 PM   #3
john
member #16
john's Avatar
You have to remove the lock cyl. first. Turn switch to acc. position and insert wire into hole on face of lock and push in. You will feel a spring loaded pin as you push. Then turn cyl to the left and pull. You might have to wiggle it a bit , but it should pull out.
john is offline   Reply With Quote
