02-05-2011, 09:42 PM | #1 |
what is the secret
to removing the junction block (the main one) that comes through the firewall for the lights and such. I am removing that harness and putting another old one back in. this in my 1t as the fuse block is all screwed up. i know that the grommet is separate from the junction
thks ron |
02-06-2011, 08:56 PM | #2 |
Re: what is the secret
amazing 24 hrs almost. 67 views and not one response
thks ron |
02-06-2011, 09:01 PM | #3 |
1 thing at a time is progress.
Sorry, I'd respond to the question (if I knew the answer), but I really don't understand the question being asked. Maybe I'm a little slow.
Alan
Philippians 2:14-16 |
02-06-2011, 09:15 PM | #4 |
thks Alan. where the main wire junction goes through the firewall between the m/c and firewall,. it disconnects there and there is that hard rubber grommet that goes around it. Hows does one remove it without destroying it(or can you) next . how do you put it back together again. everyone that redoes their wiring takes it out. what do you put back in
ron |
02-06-2011, 09:42 PM | #5 |
Uploaded with ImageShack.us here are 2 of them . the one on the left still has part of the firewall around it and the the other one which is separated. how does one put that back together in the firewall ron |
02-06-2011, 09:42 PM | #6 |
this one?
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel |
02-06-2011, 09:43 PM | #7 |
ahh you beat me to it!
02-06-2011, 09:53 PM | #8 |
I'm guessing here. I removed mine over 3 years ago. From the pics I'd clean up the grommett and reinstall. Then lube the connector with KY or a suitable lube and slip the connector back back in the grommet. I could be completely wrong just my .02. I don't think I have my old harness, but will check my extra cab and see if it has it in it.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 02-06-2011 at 09:55 PM. |
02-06-2011, 10:13 PM | #9 |
Resistance is Futile
I use white grease on that stuff, but being so old the parts are not very pliable anymore.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-06-2011, 10:52 PM | #10 |
thank you. it is pretty stiff
ron |
02-23-2011, 10:03 PM | #11 |
By rondavid at 2011-02-23 I think that I found the secret to these grommets. does anyone know if you can get new ones and or what do you use with a new harness. anyway as the they do get quite hard with age and are a sob to get out, they do go back together quite slick. just before you are to reinstall them, one puts them in the microwave for about 1 min on high and they should come out quite pliable, like new. use some white grease on them, inside and out. right away put them in their hole in the firewall and immediately install the junction block in it. done. if you fart around to long and it will harden up again, so just put it back in the microwave till it is pliable again. so I imagine if one could find away to heat it up without damaging anything, it would make it a lot easier to take apart in the first place ron |
02-23-2011, 11:20 PM | #12 |
How did you figure that out??
02-24-2011, 02:00 AM | #13 |
most things are malleable with heat so I gave it a try in the microwave. just to what degree
ron |
02-24-2011, 11:11 AM | #14 |
Those grommets are available at classic parts ( formally chevy duty ), and i suppose Lmc and the others that deal with our year wiring. The big grommet runs about $4.00
Members i've met: LiLRed66 |
02-24-2011, 11:18 AM | #15 |
1960 GMC Burb
Sounds like a heat gun would work in removing it from the truck. That should heat it up and make it more pliable. Maybe even help in the re-install by keeping the temp up, just don't melt the wires/plastic connectors.
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
02-24-2011, 11:42 AM | #16 |
http://www.truckandcarshop.com/trucks60_72/t60_030.html
There are some here also.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
07-01-2012, 03:29 AM | #17 |
But Found Her 25yrs Later!
Here's another thread on this topic:
http://67-72chevytrucks.com/vboard/s....php?p=5463129
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-01-2012, 04:01 PM | #18 |
I was hoping to get some more input on this.
I'm trying to get it out of my 65 today. Posted via Mobile Device
07-01-2012, 05:34 PM | #19 |
the centre section goes out towards the back. it sits behind a lip with the use of some small s/drivers you can get it out of there. a little white grease or vaseline in there will help. It is just that the rubber has hardened up
ron |
07-01-2012, 05:53 PM | #20 |
Thanks, I'll give it a try.
07-02-2012, 03:14 AM | #21 |
Got it.
It is quite a task. Thanks again. Now to clean up the 'birds nest'
07-02-2012, 03:37 AM | #22 |
[I]did find it easier to drop the wires out of the receptacle. just make a tool out of gas welding rod ( or an old wire coat hanger) . flatten it out with a hammer and then make it a little narrower to go in and release the little locking tab that holds the wire end in. should have told you before. just gets all of the wires out of the way. the wiring diagram in the assembly manual wire give you the order of how they go back in. you have to take them out for the microwave . only give it 20-30 mseconds at a time until it is pliable when you want to put it back and do it while it is still warm
ron ron |
