02-05-2011, 10:13 PM | #1 |
removing instrument cluster in my 63
Hi all
Any one out there that can tell me how to remove my cluster? all of the screws are out and the speedo cable is off, it slides about 1/2 way out and seems like something is holding it. HELP! |
02-05-2011, 10:51 PM | #2 |
Enjoy your truck
Re: removing instrument cluster in my 63
I suspect it is just getting hung up on the opening, if you have the screws out and the cable undone.
A good pull should get it out and then you can unplug the cluster wiring. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
02-05-2011, 11:03 PM | #3 |
Take a flat blade screwdriver under the bottom edge of the cluster and gently lift while working it out...
Bob |
02-06-2011, 12:19 AM | #4 |
It help to remove the light switch too.
http://67-72chevytrucks.com/vboard/s...d.php?t=205001 |
02-06-2011, 02:47 PM | #5 |
when taking out the one from my 64, it got hung up on some tabs sticking out from the metal dash hole. they didn't have anything to do with the mounting of the cluster or switches so I just bent them down with some pliers and the cluster came out easy.
take a look with a trouble light underneath and see whats catching. |
02-06-2011, 08:02 PM | #6 |
Thanks Y'all
I Think I'll Crawl under there this evening |
