Old 02-06-2011, 02:42 AM   #1
cdel
Insert/Modification to Gas filler tube for modern gas pump nozzles.
1977 C10 250
Has anyone ever come across an insert or modification that would allow most of the modern gas pump nozzles to rest during filling. Around here it seems that many of the stations have a nozzle which must be held during filling to keep it from falling out.
Thanks!
cdel is offline   Reply With Quote
Old 02-06-2011, 07:20 AM   #2
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Re: Insert/Modification to Gas filler tube for modern gas pump nozzles.
LOL,, ya, I hate those stations.
But I understand laws in county's or states make the stations take those off.
What I do when I full up my company ride is,,,,,, Start pumping gas and wedge the gas cap in between the lever and bottom side of handle,,,, and TAAADAAAA,,, Hands free,
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 02-06-2011, 08:45 AM   #3
one low c10
haha I do the same thing.
one low c10 is offline   Reply With Quote
Old 02-06-2011, 10:13 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i dont know how true it is but ive seen stickers on the pumps in NY that say its against the law to do that with the gas cap.. in NJ where there are gas attendants they still have the handles that lock open
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-06-2011, 11:03 AM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
Use a long bungee cord or tie-down strap hooked to the inside lip of your bed to the nozzle handle to hold it in the tank then prop your cap under the lever if it doesn't have the latch !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-06-2011, 11:09 AM   #6
camshaftgsxr
camshaftgsxr's Avatar
this thread makes me lol.. so much work to keep from holding a gas nozzle.
here in NC the nozzles kinda wedge in the opening using the weight on the fuel line connecting it to the pump
camshaftgsxr is offline   Reply With Quote
Old 02-06-2011, 11:29 AM   #7
Restrorob
Restrorob's Avatar
Must be a young buck huh ?
My bad back won't let me bend over next to my lowered truck for 20+ gals, Especially with a plug filtered running slow pump !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-06-2011, 11:55 AM   #8
camshaftgsxr
what do the nozzles look like down there? ours are just one inch around and sit down in the hole perfectly. granted some of the stations have taken the lock off of the premium because its so expensive.
Old 02-06-2011, 12:11 PM   #9
S10Fan
Old Heap Driver
1977 C10 250
Thanks!
Welcome to the site!
The way I read your question.....................You're looking for something to keep the nozzle from falling out of the filler neck, correct? The older necks were for the leaded fuel from days past. When cars/trucks were required to run lead-free fuel the necks were changed to keep leaded nozzles from fitting.
You could try and round up a neck from a later model truck.
BTW.....Trivia question......What brand fuel was the first to be lead-free? Hint, the brand has always been lead-free since 1915.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-06-2011, 12:20 PM   #10
tucsonjwt
Some turn the pump nozzle upside down when filling, but normally that still requires holding the trigger while fueling. When I try that, the wire wrapped around the outside of the nozzle tends to get stuck in the filler neck. A few stations around here still have the relatively long, gently curved, no outside wire around the outside nozzles - those fit the curve of the old filler necks nicely and allow for using the trigger hold down clip.
tucsonjwt is offline   Reply With Quote
Old 02-06-2011, 12:54 PM   #11
Restrorob
Restrorob's Avatar
I'll chime in on that with Amoco !
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-06-2011, 01:29 PM   #12
S10Fan
Old Heap Driver
Correct! Remember the term "White Gas"?
Funny story about unleaded gas..............My Dad owned an Amoco station for many years, I pretty much grew up there. As the government required all gas to be unleaded our customers were complaining how the unleaded gas was going to ruin their cars. We would break the news to them how they had already been using unleaded gas. LOL.
Bryan
Old 02-06-2011, 01:37 PM   #13
Restrorob
Restrorob's Avatar
Very well..... That was the first thing that came to mind when I read your question. LOL
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 02-06-2011, 01:56 PM   #14
f.monroe
f.monroe's Avatar
1977 C10 250
Thanks!
I assume you must be in an area that uses vapor recovery nozzles at the dispenser . If that is correct ,and they are using a balance system,then the nozzle will have a rubber tipped sleeve around the spout of the nozzle. The rubber tip has to be pushed against the tank until it seals . It also pushes the seal and sleeve back and engauges the nozzle lever . Without the pressure against the sleeve the nozzle will not engauge . If this is what you are using then you pretty much have to keep pressure on it while fueling . If you let off on the nozzle it will disengauge the nozzle stopping flow . That would be the only type of vapor recovery system I can think of that you would have to hold the nozzle . All other VR systems and even the non Vapor recovery systems the nozzle will stay in the tank without any pressure being applied . Those systems can be bypassed by blocking the lever open but it is not advised . The balance system is the only system I know of that requires you to physically hold pressure on the nozzle to keep it engaged.If your nozzle looks like the one pictured then you will have to keep pressure on it while filling or figure out a way to keep it compressed while using it .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-06-2011, 06:12 PM   #15
camshaftgsxr
^ it makes good sense to have those, the amount of chlorofluorocarbons released while you fill up is more than a prius releases driving across country
Old 02-06-2011, 11:07 PM   #16
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
We have that type here. I have managed to find a balance point where I can set it and forget it. But I do have to remember to lift up on the nozzle before I take it out, or I spill about a half a cup. It's like the tip of the nozzle rests on the top of the neck.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 02-07-2011, 10:12 AM   #17
76stepsidechevy
Id just get a filler neck out of a newer truck, anything that never had cats on it will probably have a bigger opening in the filler neck.
76stepsidechevy is offline   Reply With Quote
