Old 02-06-2011, 10:37 AM   #1
CVA59
Setting Wheelbase
What is the most effective and accurate method of getting the wheelbase back (rear end) to its original spot? I am moving the trailing arms straight inline with the frame rails and using a S10 rear end. Everything is cut loose and right now. I guess i am looking for some little tip or trick that will save me the hassle of how i have always done them in the past, LOL.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 02-06-2011, 04:40 PM   #2
scotts62
One day...
scotts62's Avatar
Re: Setting Wheelbase
I have set them up using jack stands with the wheels off and using factory holes (providing they are on both sides and in the same spot) and doing a ton of measuring to get it back to where you want it. When i built my frame i actually moved the rear end back to make it center up in the rear fenders better than they do from the factory.
Scott
93 crew cab build
Project 62
Old 02-06-2011, 05:28 PM   #3
Zack Methvin
Yes, i have also been wondering about centering it in the fender as opposed to the stock location. I may give that a try. What do you guys measure from on the front end? I have always used the lower a-arm grease fitting to establish the originating point to set the rear end from.
Zack Methvin is offline   Reply With Quote
