Wires to starter?
I did the HEI swap and used the instructions from the forum. One thing I couldn't find for sure was the wires to the starter. I have the big power wire from the battery and a purple wire going to the "s" terminal on the starter. Are these the only wires I should have?
Car Knocker
Re: Wires to starter?
Been a long time but that sound right. The other wire that went down there was like a bypass in the start position from the old points wire to get 12 volts to the starter solenoid.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
![]() Join Date: Feb 2010
Yes, that's all you need.
Posted via Mobile Device |
#4 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Car Knocker
Aw Heck, story of my life. Kinda right, but when everything all said and done. Wrong again. Hope you get you truck going.
Thanks guys. Now if I can just get it spinning fast enough to fire. I am going to pick up the new 350 this week and wanted to get the old 307 running before I took it out. That way I can make sure my wiring is right and if I decided to sell the 307, I could let the buyer Know it will run.
