Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 02-06-2011, 01:12 PM   #1
mbgmike
Quick fuel 750 carb fx-4750
JUST $850 EACH-COMPARE THAT TO $972.00 AT JEGS OR SUMMIT
Description: QFX Series Carburetor, 750 CFM, 4-Barrel, 1.710" Venturii, Bell Boosters, 2-Circuit, Gasoline, Each
Features: QFX SERIES DRAG RACE CARBURETORS
Features include, all-new aluminum main body with lengthened venturii section for greater mid-range torque and smoother air flow entry provides a stronger signal, less turbulence, and improved fuel emulsion for better combustion.
CNC-machined billet annular boosters, metering blocks with a 3-circuit metering and changeable emulsion, idle feed, and feed discharge. Die cast aluminum large capacity fuel bowls with dual sight glass, patented “Fuel Chute” design and dual inlets. Fuel QFX-Series carburetors feature Quick Fuel's external linkage with four different links to select the amount of primary throttle opening before the secondaries open: moderate progressive (25 percent), medium progressive (40 percent), full progressive (50 percent), and 1:1.
Other:
Characteristics: Part Type: Carburetors
Part Number: QFTFX-4750
Number of Barrels: 4
CFM Rating: 750
Venturii Size: 1.710"
Carburetor Flange: 4500 Series
Main Body: Aluminum
Throttle Plate Size: 2.125"
Secondary Type: Mechanical
Fuel Bowls: Die-cast aluminum with dual sight glass
Fuel Inlet: Dual
Carburetor Finish: Tumble polished
Metering Blocks: Billet aluminum, red anodized
Ford Kickdown: No
Booster Type: Bell Billet Annular Discharge
Throttle Linkage Type: Universal, Progressive
Fuel: Gasoline
Quantity: Sold Each
2 IN STOCK-SHIPS MONDAY
PM OR SEND EMAIL TO mikesbumpandgrind@earthlink.net for more info
visit
http://www.quickfueltechnology.com/
mbgmike is offline
Closed Thread
