Old 02-06-2011, 06:46 PM   #1
gotchamel
Exposed flywheel?
A recent purchase,69 C10 with a 307/700R4.I noticed today after the first good look at everything the bottomside of the flywheel is exposed,no cover.Its been along time{30+ years}since I have fooled with older trucks,is there supposed to be a cover/shroud over this opening?Thanks,Mel.
gotchamel is offline   Reply With Quote
Old 02-06-2011, 07:01 PM   #2
Pizzalovr36
Re: Exposed flywheel?
its good to have one got an extra cover in the garage.
Pizzalovr36 is offline   Reply With Quote
Old 02-06-2011, 07:01 PM   #3
kacz81
kacz81's Avatar
your missing the "inspection cover" you can pick one up cheap at your local junkyard if i recall i think i paid $ 5.00 for mine
kacz81 is offline   Reply With Quote
Old 02-06-2011, 07:03 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
I've been without one for seven years. I realize it's there for a reason and probably should be in place, but I just never did get one.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-06-2011, 07:03 PM   #5
gotchamel
Thanks,are all sbc inspection covers the same no matter the tranny?
Old 02-06-2011, 07:06 PM   #6
lofly'a
lofly'a's Avatar
i would get one for a 700r4 to avoid any small differences, and there were a few.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 02-06-2011, 07:07 PM   #7
gotchamel
Thanks,are all sbc inspection covers the same no matter the tranny or does the cover match up with the tranny?
Old 02-06-2011, 07:02 PM   #8
cdowns
cdowns's Avatar
yes there is supposed to be a cover its made of plastic// i've run vehicles for long periods of time without one with no ill effects//some guys say it damages torque converter without the cover, i've never seen proof of that
Old 02-06-2011, 07:02 PM   #9
dan42
dan42's Avatar
A lot of guys will run them without it, but it might be a good idea to put one on. My '70 didn't have one for over five years, and no problems.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-06-2011, 07:05 PM   #10
lofly'a
lofly'a's Avatar
yes, you can pick up a used one from a salvage yard for a 700r4. get the bolts too as they are metric. if you pull the parts yourself you should only need a 10mm wrench. you may need to remove the exhaust y-pipe if it is still installed. your truck, if it came from the factory as an automatic, had a metal cover, but the newer ones mid 80's to 98 are plastic. the metal cover will work but you'll still need the 4 metric screws.
Old 02-06-2011, 07:12 PM   #11
AirSpeed
AirSpeed's Avatar
I ride my Mt bike on the hiway on occasion and I have seen many laying on the side of the road! I think by the time guys get done putting a new tranny in, they get lazy, lose the bolts and use something "close" or just don't bother to tighten them up all the way. Next time I see one I'm going to pick it up.
AirSpeed is offline   Reply With Quote
