Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-07-2011, 02:03 AM   #1
champions53
Need help keep blowing fuses
Ok prob just a rookie moment for me but, inline fusable link one going into cab near firewall driverside blew on my 81 then alt overcharged and blew ignition module. So I replaced fusable link with inline fuse and new module also new altenator. Everything seemed fine but started blowing the fuse now at anything above idle. Im lost please help.
champions53 is offline   Reply With Quote
Old 02-07-2011, 05:28 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Need help keep blowing fuses
Check your grounds. You have a bad ground somewhere. Ground the engine properly to the frame.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-07-2011, 07:57 AM   #3
BigBlocksRule
edited
BigBlocksRule is offline   Reply With Quote
Old 02-07-2011, 11:44 AM   #4
champions53
Checked grounds and cleaned look good. Still blows fuse though. I hate electrical issues my weak point and it sucks.
Old 02-07-2011, 01:23 PM   #5
panhandler62
Java Mechanic
panhandler62's Avatar
Bad grounds don't tend to blow fuses. Fuses melt from excess current. Grounds are so frequently the malady in these old trucks that we sometimes leap to quickly to that conclusion.
I'm not real familiar with the wiring in an 81 but it sounds like a regulator issue to me.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 02-07-2011, 01:59 PM   #6
fixit-p
fixit-p's Avatar
Sounds like you have a bad short somewhere. What type of fuse and what amperage are you using?
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 02-07-2011, 07:19 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
are you still overcharging?
Old 02-07-2011, 08:05 PM   #8
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Check the red wire in the flat plug that is plugged into the alternator (make sure it is red and not brown), it should read battery voltage to tell the alternator when and how much to charge. It is a good bet that this wire has lost connection to the battery and the alternator is going full charge. If you have only toasted the module consider yourself lucky as I have seen 18 plus volts and complete digital dash panels gone to toast with this problem. Good luck, Roger
CaptRMW is offline   Reply With Quote
Old 02-08-2011, 12:50 AM   #9
champions53
Thanks guys for the help! When a get another day off Im going back at it again to check the stuff you have pointed out. Ill update this weekend.
