02-07-2011, 12:00 PM | #1 |
Head lights
I wanted to run this past you all. I've got parking lamps and tail lights, but no headlights. I put in a new headlight harness and a new headlight switch. It appears to be all grounded right, but the lights don't turn on.
I thought I'd run it past you before I went and ordered a front harness. Kind of got me baffled, but I'm no electrician either. Thanks guys. '70GMCStep '65 Chevy C-10 lwb bbw '70 GMC Stepside |
02-07-2011, 12:09 PM | #2 |
Who Me?
Re: Head lights
Check your connections at the firewall on the engine bay side. See if you have any voltage there.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
02-07-2011, 01:26 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Head lights
I agree with 61, if you dont have power at the core support, follow the wires back to the firewall. If you dont get anything there, then I would check you headlight switch and how the wiring is done there.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-07-2011, 03:15 PM | #4 |
Re: Head lights
check for power in and out of you good old dimmer switch. i'am thinking thats the weak point. heres a link on the wire dia http://6066gmcguy.org/headlight.htm
Trueman Last edited by 463; 02-07-2011 at 03:22 PM. |
02-07-2011, 03:21 PM | #5 |
"Where were you in '62?"
Re: Head lights
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
02-07-2011, 03:26 PM | #6 |
Who Me?
Re: Head lights
Your issue is going to start at the headlight switch. Find the pin on the switch for the headlights. Trace that forward thru the firewall to the core support. There should be a plug on the driverside coresupport behind the headlights if I remember correctly.
02-07-2011, 03:29 PM | #7 |
Re: Head lights
Thanks for the advice guys. I'll take this to the garage.
02-07-2011, 09:21 PM | #8 |
Resistance is Futile
Re: Head lights
I've had the connector at the core support come loose after putting on a new grill. Check connections and grounding if everything else appears to be correct.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
02-07-2011, 10:34 PM | #9 | |
Re: Head lights
Have you tried both high and low beams?
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
02-07-2011, 10:37 PM | #10 |
Senior Enthusiast
Re: Head lights
It's helps if you also put dielectric grease on all the connectors like at the bulkhead and dimmer switch. It provides a better electrical connection and also keeps them from corroding/deteriorating.
02-08-2011, 02:03 PM | #11 |
Re: Head lights
Yeah, I am not getting dim or bright on the headlights. The connection is good at the radiator support and the same result occurs with the new headlight switch and the old one that may have still been ok.
I picked up a voltage checker last night and dielectric grease I will need to pick up. I'll check all that and see where it goes. What I'm needing to do someday anyway is replace the underdash harness as it shows wear and tear. Thanks again for the advice. I'll post what turns up. '70GMCStep '65 Chevy C-10 lwb, bbw '70 GMC Stepside |
02-08-2011, 03:05 PM | #12 |
Re: Head lights
fuse?
02-08-2011, 03:18 PM | #13 |
Re: Head lights
Hey as far as fuses go, which one do we need? There are many at parts stores that are the same sizes, I am assuming that a 32 volt or lower is fine? I've not done any upgrades yet (wiring is the only thing not new/rebuilt on my truck)
I picked up a set of these today. I might try to post a picture of my underdash harness and see what you all think. '70GMCStep |
02-08-2011, 03:36 PM | #14 |
Who Me?
Re: Head lights
Did you get any voltage at the core support connection?
02-08-2011, 04:51 PM | #15 |
Re: Head lights
I'll go home and tinker some more. Using computer at work since mine is getting repairs. I'll see what I find.
02-08-2011, 10:37 PM | #16 |
Hell yeah!!!
Re: Head lights
I had a similiar problem on my truck and it ended up being the high beam switch was bad. Installed a new one and they worked.
Stock is good but custom is the sh*t! |
02-11-2011, 02:08 PM | #17 |
Re: Head lights
Hey guys,
Finally got to my garage this week and I have voltage at the headlight switch, (all except the white wire which is the ground??) voltage at the horn, voltage reg., alternator, dimmer switch on the floor, and fuses. Have no voltage at the firewall, and support where the front harness hooks up to the headlight harness, which is new. Wiring bad somewhere on the front harness from firewall to radiator? '70GMCStep '65 Chevy C-10 lwb, bbw '70 GMC Stepside swb |
02-11-2011, 02:58 PM | #18 |
Re: Head lights
look at the connector on the FW, I had one of the blade connectors slide back away for the front harness connector back when my truck was original.
02-11-2011, 02:58 PM | #19 | |
Re: Head lights
If you pulled the engine side harness off the plug at the firewall, and tested the metal tabs on the firewall, the problem is in the dash portion of the harness.
02-11-2011, 03:33 PM | #20 |
Re: Head lights
Sounds good. I'll give it another go. I'm checking this periodically at work since my home computer is at the doctor and won't be back until next week. I'll try it this weekend again and see what happens.
Thanks for the advice guys. '70GMCStep '65 Chevy C-10 lwb, bbw '70 GMC Stepside swb |
02-12-2011, 09:09 AM | #21 |
Senior Car Nut
Re: Head lights
headlights aren't fused on our trucks. white wire should be for the dome light according to the diagram.
when you said you had power at the dimmer switch, did you mean power out both sides (high and low, depending on position) as well as power into the switch? the out wires from the dimmer switch should run directly to the firewall plug. if the dimmer switch is working, the problem is porbably the firewall connector. I got so tired of mine giving problems I just by-passed it, running wires from the dimmer switch thru the firewall. I did this when I wired relays into the headlight curcuit to take the load off those wienie OEM wires. here's another diagram that's a little easier to read: http://67-72chevytrucks.com/vboard/s...d.php?t=324713
Larry Last edited by fleetsidelarry; 02-12-2011 at 09:17 AM. |
02-12-2011, 09:35 AM | #22 |
Re: Head lights
Hey wait a minute.
This is a stupid question, but should the dimmer switch be showing power whether on bright or dim? I think that is what you are saying. I hope you are, because I have no power whatsoever on the dimmer when the switch is on "dim", just on "bright". If that's the case, maybe this is solved? Thanks, '70GMCStep '65 Chevy C-10 lwb, bbw '70 GMC Stepside swb |
02-12-2011, 09:47 AM | #23 |
Senior Car Nut
Re: Head lights
when you pull the headlight switch on, it sends current to the dimmer switch, which routes it to either low or high, depending on the switch position. there's no "off" position. what sort of tester are you using?
Larry |
02-13-2011, 12:14 AM | #24 |
Re: Head lights
The cheap Harbor Freight kind that you ground and then the light comes on when there is voltage. Probably not the best even for an amateur though.
No voltage or lighting up when testing dimmer switch on "dim". |
02-13-2011, 09:45 AM | #25 |
Senior Car Nut
Re: Head lights
Actually, a test light is perfect for this sort of problem. no need for anything more sophisticated, although, if you plan on working on these old trucks very much, you might want to invest in a better one.
if I understand, 1. you have power in to the dimmer (blue wire) and power out in one position to high beam (green wire) but no power out (to the tan wire) the next time you click the switch. and, 2. even with power coming out in the high beam position (into the green wire), you have no headlights. if #2 is true, then you still have a problem between the switch and the headlights. to check the dimmer switch, pull the plug from the dimmer, make a short jumper wire, and bridge the connections (one at a time), blue to green and then blue to tan, and see if you have headlights in each of those configurations. if not, pull the firewall plug and see if power is getting to the connectors. its a matter of tracing the current to the fail point and you may have to unwrap some wires to follow their path.
Larry Last edited by fleetsidelarry; 02-13-2011 at 09:47 AM. |
