Old 02-07-2011, 04:16 PM   #1
Lemield
Lemield's Avatar
In cab hood release
Here is my version of Putters and 68w/sbc406's in cab hood release.....
http://67-72chevytrucks.com/vboard/s...d.php?t=136797
My addition was a threaded adjuster from a bicycle brake cable. I welded in a 6 MM nut and voila.....I used a billet cable setup from Watsons Street works..
http://www.watsons-streetworks.com/
I mounted the cable under the dash....works nice. I decided to fabricate this because I installed the LMC billet grille and the extension rod for the latch is pretty crappy...at least I thought so.....
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 02-07-2011, 07:28 PM   #2
barryvanhook
barryvanhook's Avatar
Smile Re: In cab hood release
You aren't the only one ... I scrapped the one that came with my billet grille after trying it without a great deal of success. I substituted a length of all-thread with a round ball on the end ... I can push it up with the toe of my shoe to release ... a much better solution than their extension rod. Maybe not better than yours!
Barry L. Van Hook
'69 Chevy Frankentruck
barryvanhook is offline   Reply With Quote
Old 02-07-2011, 08:25 PM   #3
6772owner
Gearhead
6772owner's Avatar
Im gonna have to talk you into doing this mod for me too, twice!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 02-08-2011, 09:30 AM   #4
Lemield
Lemield's Avatar
My welding skills are nothing to brag about but I'm sure we can work something out....
Larry
Old 02-08-2011, 09:42 AM   #5
6772owner
Gearhead
6772owner's Avatar
Sweet, its mostly just the parts involved, my bro welds like a mad man!
Old 02-08-2011, 09:46 AM   #6
Lemield
Lemield's Avatar
I've got enough steel to make at least one more......the adjuster screw came from a local bike shop's scrap bolt bucket for free...17 cents for the nut....
At the very least, I can show you how it all goes together. If the cable I used ever has a problem, I will replace it with a lever style cable from Watsons.....the lever style would work a lot better.
Larry
Old 02-08-2011, 11:21 AM   #7
6772owner
Gearhead
6772owner's Avatar
Ok cool, sounds good to me, we'll have to get together when better weather rolls around. I guess if you're coming to the GTG, I could see it then as well.
Old 02-08-2011, 04:10 PM   #8
Lemield
Lemield's Avatar
Barry...I like your solution. I left the lever (just shortened for grille clearance) on the latch just in case my cable breaks....I carry a big old long wrench (equalizer) in the truck that I can use to push up the latch if I need to....
Larry
Old 02-08-2011, 04:13 PM   #9
Lemield
Lemield's Avatar
Sounds good. I saw the thread for the GTG.....sound interesting...would have to talk my wife into it but I'd love to meet more truck people....
Larry
Old 02-08-2011, 05:19 PM   #10
Luvlegs
Luvlegs's Avatar
Hey all - I put in a one piece cable - cab to front - very similiar mounting - everything moves EXCEPT when the hood is shut. I welded the two "arms" together so there's only one "release". I backed out the hood pin almost to the point that my body lines are off. Everything is lubed. I broke the tip off the main release spring (to relax it more) - I took off the small spring in the release.
ISSUE - I have to stand on my tip toes, hold the pull handle with both hands and throw myslef into for all I'm worth aaaaannnnnndddd - ugh, it pops! Any suggestions?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 02-08-2011, 05:23 PM   #11
Lemield
Lemield's Avatar
I did have to adjust my hood pin a bit and it is still a hard pull....but not really terrible...that's why I think the lever type cable would be better. Sounds like you did everything to make the thing easier to pull...sorry I don't have any more ideas...
Larry
Old 02-08-2011, 05:27 PM   #12
Lemield
Lemield's Avatar
Is yours welded like this?
Larry
Old 02-08-2011, 05:32 PM   #13
Luvlegs
Luvlegs's Avatar
sure looks like it - I made sure it moves like it should (and it does when the hoods not closed)
1972 C10 L6 3OTT
Old 02-08-2011, 05:50 PM   #14
Lemield
Lemield's Avatar
Dumb question....but I gotta ask since it happened to me....is the lever that you welded on to the release possibly hitting the radiator or the A/C condenser? On mine, it was hitting the A/C condenser so I had to grind the end back a little bit. I also put two thin washers behind the two upper bolts. This gave it a bit more clearance. Just a thought....
Larry
Old 02-08-2011, 07:52 PM   #15
Luvlegs
Luvlegs's Avatar
Well it might help somebody else but I don't have AC and the radiator is not in the way. Keep going though! I was thinking about taking out the "big" spring and replacing the little one with a stronger one but I'm not sure just how much "looser" I want that release to be.
I can still JUST reach through my grill and pop it now (I won't cut the front off until it works real nice)
1972 C10 L6 3OTT
Old 02-09-2011, 09:36 AM   #16
Lemield
Lemield's Avatar
The cable I used has a plastic or teflon lining. I learned about teflon lined cables on my Harley after replacing an old clutch cable with a new lined one...what a difference. Anyway, if your cable is not lined, it might be contributing to the hard pull. You might be able to put some cable lube in the housing...that might help too. I also used a cable clamp on the radiator mounting to help keep the cable from moving. Just a couple more thoughts....
Larry
Old 02-09-2011, 09:44 AM   #17
steelscout
Words under my name
steelscout's Avatar
Too bad there isn't a bolt-on application for this, since I don't have the skills to do this type of work, I would be very interested in having this added security...
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 02-09-2011, 11:29 AM   #18
CEE1NG_RED
Did you get the cable from a later model suburban??? I saw a few @ my local junkyard, but didn't bother taking it out until I know more info. about this mod.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 02-09-2011, 12:40 PM   #19
Lemield
Lemield's Avatar
I used a cable from Watsons Street works....Part number #CC-UB10
http://www.watsons-streetworks.com/cable_releases.html
Larry
Old 02-09-2011, 01:43 PM   #20
treveiger
treveiger's Avatar
ss
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 02-11-2011, 11:04 AM   #21
Lemield
Lemield's Avatar
Hey LuvLegs,
I went out to the garage last night and tried to unlatch my hood release and it appears to be having the same problem as yours. I put it together when it was warm but it's been very cold lately and now it's not working. This morning I ordered a lever style cable from Watsons. I will let you know if it solves the problem.
Larry
Old 02-11-2011, 12:45 PM   #22
Luvlegs
Luvlegs's Avatar
I bought a 8' "solid" core pull at tractor supply. It's smooth and all works when the hood is up. I took the hood pin out and cleaned it very nicely, even a small dallop of grease on the back. No luck. I'm thinking the solenoid popper is the way to go (before I throw myself on my back when my hands slip off!). I made sure to keep nice sweeps in the line, no kinks or close turns. I'm thinking about taking the big spring out and putting a fatter one on where the little on is.. just want it to be safe though.
1972 C10 L6 3OTT
Old 02-11-2011, 12:49 PM   #23
Lemield
Lemield's Avatar
The guy on the phone at Watsons suggested putting a spring on the latch to provide some preload so that the pull isn't so hard....don't know how I'd do that though....
Larry
Old 02-15-2011, 02:55 PM   #24
Lemield
Lemield's Avatar
Ok...I ordered a new lever type cable from Watson's last Friday.
This past weekend, I took the hood release apart, put some cable lube in the cable and lubed up the latch itself. I also noticed that the hole in the lever that I added to the latch didn't line up very well with the upright part that I built...so I drilled a new hole. I also shortened the cable a bit. I also relaxed the tension on the spring a little bit. It is now working pretty smoothly.
I will keep the new cable and use it when this one breaks or quits working.
Larry
