Roadtrip!
![]() Join Date: Feb 2003
Help with bracket ID...
Found these in my parts pile and i don't recall taking them off from any thing. Any ideas? The smaller one looks to have a number of 338784 best i can tell. Thanks.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Help with bracket ID...
67-70 engine stop lift brackets that mont to the exhaust manifold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Member #1049
Eric,
The smaller one looks to be the factory cable bracket to keep the engine from lifting. it bolts to the exhaust manifold and has a cable attached to the frame.. The other one is a smog pump bracket for a long water pump.. cannot tell from the pics if its for a BB or SB. the only difference is the bolt spacing, they bolt down on the front of the block by the fuel pump Last edited by Livrat; 02-07-2011 at 11:40 PM. Reason: spelling |
What?
Early 70's smog pump brackets.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Roadtrip!
Thanks for the help guys. Maybe that will explain the lift cable i have here also...
Eric
What?
I can safely say that the one with the welded on nut, is the smog pump bracket that bolts to the engine block on the passenger side.
But, the other one after staring at it some more. I'm not sure now what that one is, since it looks bent and one end looks chopped off?
Roadtrip!
Vectorit, I can post up some more pics if you like...
Is the smog pump bracket worth anything? Eric
What?
Those smog pump brackets are worth something to the right person, and recycle material to the next person. Just like I thought all those stock air cleaners and radios were worth nothing when I threw them away years ago, now stuff like that is worth a lot to me and I kick myself for chucking all of that stuff.
