Old 02-08-2011, 12:05 AM   #1
theyaehoo
truck ran like it was running out of gas
I was headed up a hill and the truck acted as if it were running out of gas, the gage does not work (on order from LMC) I made it to the top, coasted down the other side and luckily made made it to a gas station, but it only took 10 gallons. I am thinking, filter, pump or vapor lock. any suggestions will be appreciated.
theyaehoo is offline   Reply With Quote
Old 02-08-2011, 12:10 AM   #2
71AteLugger
71AteLugger's Avatar
Re: truck ran like it was running out of gas
Could be a bad n.i.s. in the carb... usually caused by a clogged or missing filter. Just my thought...
As for me and my Chevy, we serve the Lord.
Joshua 24:16
71AteLugger is offline   Reply With Quote
Old 02-08-2011, 12:13 AM   #3
theyaehoo
After this, it ran ok, then twice again it did the same, I slowed to below 60 and it recovered. Thank you for your help, I will pull the filter in the morning.
Old 02-08-2011, 12:16 AM   #4
70jnktrk
70jnktrk's Avatar
nice looking truck...ever checked the condition of the fuel pickup sock in the gas tank?
70jnktrk is offline   Reply With Quote
Old 02-08-2011, 12:18 AM   #5
theyaehoo
No I haven't, great idea, I had a vette once and pulled it, it was trashed. Thanks for the comment on the truck.
Old 02-08-2011, 12:21 AM   #6
DEISS
DEISS's Avatar
Bad gas, it`s happened to me.
DEISS is offline   Reply With Quote
Old 02-08-2011, 12:29 AM   #7
Mallory
Mallory's Avatar
Sounds like the fuel pump.
Mallory is offline   Reply With Quote
Old 02-08-2011, 12:30 AM   #8
theyaehoo
it was running ok till the hill, then I put more gas in it (10 gallons) and it ran ok for a while again, then it happened again. I just got the truck last week and it is only the second time I put gas in it, I am running the mid grade gas, 89 octane, Mobil gas. I will have the sending unit out around the end of the week so I will look at the tank, Thank you for your help.
Old 02-08-2011, 12:32 AM   #9
theyaehoo
I think that the fuel pump is reasonable, and easy enough to change, that and the filter, Thank you.
Old 02-08-2011, 05:52 AM   #10
cdowns
cdowns's Avatar
is the tank properly vented? when you remove the cap if there is a "wooshing" noise you have a venting problem
Old 02-08-2011, 10:53 AM   #11
Shyguy
Junior Member
Shyguy's Avatar
Lot of good info already.
Check the rubber hoses, one is under the cab, the other is on the suction side of the fuel pump.
Check the filter in the carb, if you have a Q-jet.
It does not sound like a vapor lock, they normally happen at times of low fuel flow.
Good luck.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 02-08-2011, 11:12 AM   #12
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
All good info, I just went through this in the last 6 months.
started with fuel filter in q-jet
make sure there is no filter between the tank and pump this will cause vapor lock
replaced fuel pump
replaced fuel cap
replaced rubber lines
rebuilt and tuned q-jet
Adjusted valves
replaced sock and sending unit. mine was trashed also (pic attached)
after all this I pulled a vacuum check on the engine it looks like my valve springs are done.
I hope yours is an easier fix.
what part of SD are you in?
mine started acting up on the 67 grade heading up to Poway.
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 02-08-2011, 12:14 PM   #13
68 IRON
68 IRON's Avatar
My money is on the fuel pump. I had an 67 El Camino that would sputter and spit whenever a hill with decent grade was involved (Vantage hill Eastern Washington).
68 IRON is offline   Reply With Quote
Old 02-08-2011, 12:16 PM   #14
theyaehoo
Thank you, I will definitely be looking into that. It will be nice to have the old truck running properly!
If you want a job done right, lower your standards!
Have a great day,
Scott
71 Custom 20
