02-08-2011, 02:14 AM | #1 |
these are engine brackets but what do they go to pics are included
i found these two brackets dont know what they go to ?
i plan on having my alt. on the drivers sdie above the power steering pump and a short water pump will these work ? were do they mount? Last edited by 67chevy1series; 02-08-2011 at 02:15 AM. |
02-08-2011, 02:31 AM | #2 |
Re: these are engine brackets but what do they go to pics are included
ttt
02-08-2011, 02:52 AM | #3 |
ttt
02-08-2011, 02:57 AM | #4 |
the top pick is for an alternator mounted on the passenger side with a long water pump....
02-08-2011, 03:00 AM | #5 |
thanks 53 burb!
02-08-2011, 06:45 AM | #6 |
The bottom picture is of the front half of the power steering bracket setup for a small block V-8.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 02-08-2011 at 06:46 AM. Reason: wording |
02-08-2011, 06:45 PM | #7 |
thanks i need all of the brackets so now i have one less to get ...
02-08-2011, 10:07 PM | #8 |
Cruzin
yea as said the top is a later model top alternator bracket here is a pic how it mounts you don't need it for your setup but i thought i would show ya anyways
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
02-08-2011, 10:16 PM | #9 |
just out of being curious how does the alt mount at bottom when you use the later model style bracket?
02-08-2011, 10:23 PM | #10 |
Cruzin
here ya go
02-08-2011, 10:41 PM | #11 |
d@mn! i have all the brackets for a passenger alt mount! this sucks i need just the opposite!
05-24-2011, 05:55 PM | #12 |
Hub,
What kind of fan are you running? How far should the fan be from the radiator?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
