posi swap
ok I have never done this but I have 2 Rear Ends.
1st one off a 1970 C-10 Leaf Spring Setup with Posi 12bolt. the 2nd one on 1971 C-10 Coil Spring Setup with out Posi 12bolt. I want to know how difficult it would be or if its possible to swap the guts inside one another. and If I would need anything special to do the job or maybe even a good Idea to purchase. I searched for a Thread and did not come across one. I also thought of just welding new perches on each one for the setup and just swapping the rear ends but I noticed the one off the Leaf Spring setup does not have any place for my Pan Hard Bar to bolt to for my Coil Spring setup. Any Help would be appreciated Thank you
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 Last edited by Jeffs70; 02-08-2011 at 08:04 AM. |
Re: posi swap
best way is to weld new perches and panhard bar mount on the posi rear
its all about the +6 inches
Re: posi swap
do a search on setting gears, you'll see it is just short of an art that not many people know or understand.
If you screw it up, then the gears will be garbage. So if you are able to weld properly, then I agree, it'd be the better choice. With all that being said, you are doing all this work for a 41 year old posi. Odds are it isn't all that good anymore. |
Re: posi swap
ok Great info to know Thank you. I am glad I didn't just dig into it and cause more problems then its worth. I may just go with welding new perches then if this is an easier way to go.
Thank you again.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
![]() Join Date: Jun 2010
Re: posi swap
I think the rear end widths changed from 70 to 71, but I'm not sure.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: posi swap
This is about the easiest first work you can do in the diff. Buy a carrier installation shim kit and a set of new ring gear bolts. Spend the extra money for the interlocking shims. You will need a dial indicator, a magnetic base, and a caliper.
Set up mag base and dial indicator, measure backlash on ring gear. Write this down! Mark both caps as to left and right and then pull caps. Remove open carrier, remove ring gear. Install ring gear on posi carrier. Use caliper to set up adjustable shim pack equal to the iron shims you pulled out. Put posi carrier back in and torque caps. Check backlash, and if it same as what it was before the swap, you are done. If it is too loose, disassemble again and remove a small shim from side opposite ring gear and install it in shim pack on ring gear side. Reassemble and measure again. Once backlash is same as it was when you started, double check ring gear bolt torque and bearing cap bolt torque. Put cover back on and add gear oil and limited slip additive. www.use-enco.com you can get a dial caliper, and mag base, and a dial indicator for less than $50. I have done this re-using the stock shims and not even checking with no problems, but that is your call to make not mine!
